2 X Blowoff valve
aep886
Real Name: Davey
2 X Blowoff valve
Post by aep886 »
i see many with 2 dump valve set up on the Sr20det when i was in NZ... does it really benifit anything or just for show?
current vehicles...
1979 Corolla SR5
1996 S14 200sx
phoenix s14
Real Name: Mark Appelgryn
Post by phoenix s14 »
BOV near turbo is for protection of the turbo. so there is no reverse flow through it due to pressure in the system
BOV near throttle body is to maintain airflow through the system.
Duel is cool since you have both advantages but a sufficient one near the TB should be good enough. :wink:
Well that's my understanding...
aep886
Real Name: Davey
Post by aep886 »
but i see most of them have 2 on the TB side!!!
current vehicles...
1979 Corolla SR5
1996 S14 200sx
poizen
Real Name: Mical Mackay
Post by poizen »
i run 2 as well one by mu turbo and one on my cold side the reason i run two is my hks couldn't flow enough with my bigger turbo so i got a lot of surge so had to add another dv in now its perfect the hks is set for high boost and the xcell for low
Gizmo
Post by Gizmo »
I've never understood the 2 dv's next to each other either :/
poizen wrote:i run 2 as well one by mu turbo and one on my cold side the reason i run two is my hks couldn't flow enough with my bigger turbo so i got a lot of surge so had to add another dv in now its perfect the hks is set for high boost and the xcell for low
How do you set a DV that works on vacuum and pressure? if its set to "low boost" that means the spring is less tens and could allow you to loose boost as well?
"Growing old is mandatory, growing up is optional"
ex: Audi A3 1.8T 204 kw atw (sold)
ex: VW Mk1 2.0 8v (sold)
poizen
Post by poizen »
Gizmo wrote:I've never understood the 2 dv's next to each other either :/
no its set to std the one and the other has a 1mm washer behind the spring to incease pressure
