For the dictator know hows!!, is it possible to run a dICTATOR 60-2 ecu with some special disc and sensors inside the cas ??, instead of the 60-2 trigger disc and pickup on front pulley ??
If yes what type of disc inside cas do i need , (4+1, 4+2 holes , sensor type etc ) ???
Yes, you will need a degree ring and no you won't need another sensor inside, you use the CAS sensor. Well all depending if it works or not, the diagram should be on the dictator website though, if u can't find it let me know an I will send it to you later
P.S. You will have more luck with getting the pickup and wheel to work properly
But degree ring can be gotten through dicktator for the correct one
