She is the CA that IS
(O=O)/RS13\(O=O) "if you only need one jack to raise your car, then your car isn't low enough"
"EVERYDAY I'M FLUTTERING!"
Yeah GT2876R is the biggest I've had and I couldn't imagine much else fitting in there. But you need to do some work to get it to spool acceptably early enough. I did everything I could excpet for some cams and it hit full boost at 4500 rpm on a CA18DET.
i am thinking on doing gt2871r on my ca will it be good with the a 53 rear housing?
They are all 53.8mm on the rear (exhaust) housing from Garret
On the Compressor side however, you get the following:
52 Trim = 51.2mm = 250-400 bhp
56 Trim = 53.1mm = 280-475 bhp
The 56 Trim is laggier, commonly people go for the 52 Trim as it's a good balance between power and spool time on the CA and SR (smaller capacity engines)
There are other versions available but they are rare as far as I know.
djtreble wrote:I don't have personal experience with the GT30's, is that proven or by hear-say?
forgot to say i have Stage 3 head package from HKS too... GT30pro... is the best i have experience... i had Trust T67-25G on the same setup with 398hp... and it has much bigger compressor but it came no where near the GT30 pro
current vehicles...
1979 Corolla SR5
1996 S14 200sx
