Ok here is the scenario ,
Timing light shows 15 deg, initian dicktator settup set to 15 deg, but when ideling, dicktator shows 30 deg...
What could be the problem???
P.S. Dicktator STD on a distributor...
Thanks in advance guys...
Once again another one for dicktator experts
- POWDER
- Real Name: Mike
- RudeBoy
- 0.5 Bar Boost
save your current map "any name you like"
in the timing map, set all the values to 15 and save it as "static"
then make sure you get 15degree on timing light, set distributor and "triger angle" on dicktator main screen till you get 15 on timing light
lock distributor and make a note of the "triger angle" value
load "any name you like" map back into dicktator and set trigger angle to the noted value
hope this helps
hope this helps
- POWDER
- Real Name: Mike
Shot Rudeboy, will pass on the info to my boets friend.
Will let u know how things come allong
