Stuck motor
P3g4sus
Club Drifter
Car: Supra
Engine: 2JZ
Real Name: B.G. Smit
Stuck motor
Post by P3g4sus »
Hi guys
So I did a rebuild for my CA, New rings and bearings, motor turns well if i torque the main bearings to correct torque setting, then I started with the bigends, everything went well till I got at No4 bigend, the the motor would turn, but very difficult, put it in the car, motor is stuck......
Any got a Backyard solution? can I pull the car in gear? trying to free the motor? Really want it to be running at japfest.
Motor is going out after japfest again!
Any help what so ever will be appreciated! thx guys!
Re: Stuck motor
P3g4sus wrote:Hi guys
Normally when a motor is stuck there is water or oil or something in the combustion chamber....take out all the plugs if any is in and try and turn the motor by hand...see what happens.... is your clutch ingaged somehow...is the car being able to move without the engine turning when it moves?
I know I sound like a dumbshit....which I am....just thinking with the little brain sells I have :oops:
P3g4sus
Club Drifter
Car: Supra
Engine: 2JZ
Post by P3g4sus »
I have checked the cyl before fitting the head, was dry as a bone, clutch works fine, I cant turn the motor by hand, tried a few times yesterday, thats why i wanted to pull it to try to turn it, I am just very desperate now!!!!
poizen
Real Name: Mical Mackay
Post by poizen »
if you desprate then just start it
after all its comming out and you will have to get your na motor or SR20DET
P3g4sus
Club Drifter
Car: Supra
Engine: 2JZ
Post by P3g4sus »
poizen wrote:if you desprate then just start it
Well, only one little problem, starter doesnt want to turn it... If I pull it, the wheels one lock up...
andre_sx
Post by andre_sx »
Sure about your bearings are the correct size and is the torque wrench not fuct
P3g4sus
Club Drifter
Car: Supra
Engine: 2JZ
Post by P3g4sus »
Yep, checked old bearings, and its a new torque wrench...
What if i pull it at 100km/h and put it in gear and drop the clutch? :P
thekoukimonster
Post by thekoukimonster »
Well im not sure about youre problem, but one thing is certain , what is not broken yet, is going to break if you keep on going at it in this way :!: :!: :shock:
P3g4sus
Club Drifter
Car: Supra
Engine: 2JZ
Post by P3g4sus »
yeah that i pretty much can guarantee, but what if it works? :P
andre_sx
Post by andre_sx »
P3g4sus wrote:Yep, checked old bearings, and its a new torque wrench...
You should get some noise from it doing that but that will be the end of it
what are the bits You replaced
P3g4sus
Club Drifter
Car: Supra
Engine: 2JZ
Post by P3g4sus »
new main bearings, new bigend bearings, new piston rings, do not understand why it will turn Wednesday night, but not yesterday?!
Get the crank re mic'ed and check bearings...
poizen
Post by poizen »
Gary57 wrote:Get the crank re mic'ed and check bearings...
he has one day
just do what you want peg 100kph and drop clutch will give nice smoke show
P3g4sus
Club Drifter
Car: Supra
Engine: 2JZ
Post by P3g4sus »
look, this weekend I want to use the car for japfest, The motor was turning when I closed up the bottom end, put it in the car, and it decides to stop, I thought of putting a bit of oil in each cyl, taking out the sparkies, and pull it, just to free it, obviously not at a 100km/h
P3g4sus
Club Drifter
Car: Supra
Engine: 2JZ
Post by P3g4sus »
And I am going to take the motor out completely after japfest, doing my conversion then
