Jacquesopper
Posts: 139 Joined: Fri Jul 02, 2010 9:14 am
Real Name: Jacques
Post
by Jacquesopper » Sun Oct 17, 2010 10:10 pm
Regards
Jacques
1991 200SX S13 Charcoal
1992 200SX S13 White
1994 200SX S13 RB25 Red
Posts: 3882 Joined: Wed Jan 09, 2008 10:08 am
Post
by Charlvdw » Mon Oct 18, 2010 8:59 am
Looking good Jacques, just a pity its a 8 port.
Jacquesopper
Real Name: Jacques
Post
by Jacquesopper » Mon Oct 18, 2010 9:06 am
Thanks Charl , whats the difference in power and performance between the 4 port and 8 port ?
Regards
Jacques
Post
by Charlvdw » Mon Oct 18, 2010 10:15 am
Jacquesopper wrote: Thanks Charl , whats the difference in power and performance between the 4 port and 8 port ?
Performance wise you should get more or less the same, just note that on the 8port the injector sits in one of the two intake ports where the 4port the injector sits in the center so you don't have a dry port. That 8port was designed with carbon canisters and additional air valves to operate the system.
Posts: 5723 Joined: Thu Aug 03, 2006 8:32 am
Post
by Draco » Mon Oct 18, 2010 2:08 pm
It's called a secondary butterfly system, it was designed to increase low end torque when used properly.
aep886
Posts: 1881 Joined: Thu Aug 09, 2007 10:19 pm
Real Name: Davey
Post
by aep886 » Tue Oct 19, 2010 12:29 pm
stock fuel system will only allow 1.2bar of boost anymore will cause problems
Jacquesopper
Real Name: Jacques
Post
by Jacquesopper » Tue Oct 19, 2010 4:26 pm
I have a Walbro fuel pump fitted , and will be fitting a fuel pressure guage as well to see if the pressure will be enough .
Regards
Jacques
aep886
Real Name: Davey
Post
by aep886 » Fri Oct 29, 2010 10:01 am
let meet up sometime man... ^^
Jacquesopper
Real Name: Jacques
Post
by Jacquesopper » Sun Oct 31, 2010 10:04 pm
Regards
Jacques
Post
by Draco » Mon Nov 01, 2010 7:52 am
Looks good....what did you pay?
Jacquesopper
Real Name: Jacques
Post
by Jacquesopper » Mon Nov 01, 2010 7:57 am
R9918 for the T28 Ball Bearing
Regards
Jacques
Post
by Draco » Mon Nov 01, 2010 7:58 am
Not to bad...enjoy!!!!
Posts: 936 Joined: Wed Oct 06, 2010 12:23 pm
Real Name: ????
Post
by Adrian » Sun Nov 14, 2010 8:40 pm
update
Jacquesopper
Real Name: Jacques
Post
by Jacquesopper » Sun Nov 14, 2010 10:06 pm
Nothing new done , did not get time to work on the car . Things are hectic with my business .
I am thinking of doing a RB25 swop on my other SX , already spoke to Wynand . Only have to decide on doing it or not and then order all the goodies for the swop .
Regards
Jacques
aep886
Real Name: Davey
Post
by aep886 » Sun Nov 14, 2010 10:54 pm
is that white S13 with black top yours? the one i sees at 2nd's all the time?
