Wanted or for sale
thekoukimonster
Post
by thekoukimonster »
Z32 afm with pigtail and used apexi airfilter forsale R1300.
Std s14 afm forsale , with airfilter adaptor R650
Nistune type 3 realtime board R1700, with s14 ecu fitted inside R2200.
Nistune usb consult cable R300
std 370cc injectors R1000
std radiator only R500
aep886
- Car: S14
- Real Name: Davey
Post
by aep886 »
how much is the Z32 AFM ??? without Apexi air filter
thekoukimonster
Post
Z32 afm alone R1100, but if selling it alone, im not selling apexi .
poizen
- Real Name: Mical Mackay
Post
by poizen »
how much for apexi then so i can get apexi and he can get z32
aep886
- Car: S14
- Real Name: Davey
Post
by aep886 »
poizen wrote:how much for apexi then so i can get apexi and he can get z32
that awesome~!!!
Post
by Riekert »
thekoukimonster wrote:Z32 afm with pigtail and used apexi airfilter forsale R1300.
oooooohhh!!! nistune!
I want! but alas... I can't have....
denoSX
Post
by denoSX »
What's the benefits of using Z32 afm?...is there any others apart from improving "tunabilty" like the interweb says!
CA18det : 130kw atw 270nm RBTS tuned
thekoukimonster
Post
denoSX wrote:What's the benefits of using Z32 afm?...is there any others apart from improving "tunabilty" like the interweb says!
It is only needed, if your maxing out your std afm, example, std s14 afm 290hp, z32afm 500hp.
But you need a tuned ecu or nistune to make it work.
Buckusa
Post
by Buckusa »
Hi I am really interested in the Nistune! when you say R2300 fitted to the std ECU do you mean it will come with the std ECU as well?
Red S14
