cone filters
KD21sx
cone filters
Post by KD21sx »
what filters do u guys use nd how do u find them pls :?:
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
simota cone filter, works fine.
k&n is also a good option if you keepin the standard air box
can get get a good cone filter anywhere really
Current. CA18DET S13
phoenix s14
Real Name: Mark Appelgryn
Post by phoenix s14 »
A 500mile test of all the filter brands out there revealed that:
1. BMC / K&N is the only filter you should use
2. Foam filters are crap - not only do they not filter well but are not any better for performance
3. buying the good filter is the good choice to make.
Honestly I would NEVER fit ANYTHING but K&N or BMC. If you value your engine - buy a quality filter. :wink:
Also do not fool yourself - a cone filter in the engine bay not shielded from the heat of the surrounds and not fed cold air from an area away from the heat is WORSE than the standard airbox with a STANDARD filter. A replacement filter from K&N or BMC is even better. Also make sure that if you are running a standard airflow meter to have at least 100mm of pipe run between the filter and the sensor to not confuse the sensor with turbulent air.
My 2c and advise. Take it or leave it :lol:
Tobie
Post by Tobie »
AEM and Apexi makes real nice filters 2
aep886
Real Name: Davey
Post by aep886 »
blitz and apexi are dyno proven to gain horse power
andre_sx
Post by andre_sx »
hentiebez
Post by hentiebez »
phoenix s14 wrote:A 500mile test of all the filter brands out there revealed that:
fully agree with you, people spend $$$$ on the engine and go and buy a cheap filter, you can add a apexi to your list to as per Tobie and Andre
KD21sx
Post by KD21sx »
thnx phoenix gettin bmc today
VegetaSSJ4
Real Name: Philip Broodryk
cone filters
Post by VegetaSSJ4 »
Another very good filter is the Apexi Dual funnel power intake kit.
It is not cheap but it gives the bes filtration to power gains
jus my 2c
---------SKYLINE---------
(O O) - - R33 - - (O O)
----------FTW!!!!----------
andre_sx
Post by andre_sx »
did youguys check the link ^^
300sx
0.8 Bar Boost
Post by 300sx »
hehe, a subject that always makes me smile this..
want the best filtration there is?
use oem paper filter + oem designed airbox..
want a bit less power and more induction noise?
use a under bonnet conefilter
want a (debatable!) bit more power at the cost of less filtration?
use a cold air induction kit with the least shitty cone filter you can find :)
all of this said, my sx also uses a k&n filter of the huge variety, which brings us to the only real reason a cone filter should be used for in my humble opinion :
when you have no choice, because the original airbox or bigger cannot be refitted due to space constraints..
:wink:
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
phoenix s14
+1 on what 300SX said. Buy a K&N replacement. :wink: alternatively buy a apexi and stick it in a cool place :lol:
aep886
Real Name: Davey
Post by aep886 »
the best is to get a ARC aluminium super induction box ... sucking air at a rate of 15.3 cubic feet per minute compare to stock flows 12.6cfm
Tobie
Post by Tobie »
The ARC looks good and works well on stock turbo plumbing.
Top $$$$ that
