Hi Guys, calling all experts here. My S14 has a rattle sound coming from the head! It sounds almost like a tin sound and only comes around when the car is warmed up and you can only hear it when it is idling. Also there is a slight oil leak coming from the head at the front. Do you think it could be a bolt on the head thats loose. Please advise.
poizen wrote:that or your timing chain loose and under no load it hits happend on my hardbody
Thanks poizen! I did some reading and also found guys complaining about the chain causing the problem. How difficult is it to fix and does it require parts???
well take your tappit covers off and see if the chan loos think it should have no more than 10-15mm play and to tighten im not sure my bakkie is a ka24de so it has hydrolic tensioner not sure with the sr20det
Yip good idea I suppose I will only know once the head comes off. Is advisable to drive it like this? do you think it will it cause any damage?
well like i say my bakkie did it i just drove and after 10km it came right but i have a hydrolic one but just take the cover off and a look if push comes to shove drive it
poizen wrote:well like i say my bakkie did it i just drove and after 10km it came right but i have a hydrolic one but just take the cover off and a look if push comes to shove drive it
