FrankenZteins back!
- poizen
- Real Name: Mical Mackay
no worries brendan any time just shout
so steering bush......chech
management.......hmmm i see us loosing hair over this one
pulleys.......prosponed
breather.....more hair lost
surge tank......soon
seat.....25liter drum
hmm what else i leave out we got alot to do in 1month lets hope we get it done right hahaha
im keen for japfest
brendans kouki lights look amazing i was going to steal them but think he would of knoticed next time hahah
im keen for japfest
- Charlvdw
What thickness is the steering bush? And the the hole sizes? It doesn't look the same as the ones you import.poizen wrote:no worries brendan any time just shout
im keen for japfest
- poizen
the bush is 20mm and the holes i think gary made them 9mm or 8.5
the import ones are thiner because you use all that other crap you just take the rubber out this one takes everything out which i think is better
but steering feels much nicer with this cant wait to fit mine
- DriftZ
- Car: S15
Hey shot boetAdrian wrote:DriftZ awesome car man
Poizen awesome work on driftz' car we need more sx like this one
Ja Big Thanks to PoiZN..... he came around yesterday again, we worked the whole day and got a lot of stuff done in the engine bay...
Radiator breather tank
New power steering tank
Alli pully's
New water pipes
new Clutch MC ( FYI - 2.4 Nissan hardbody is a direct fit to allow Greddy style Intake manifolds, its 2.5cm shorter )
match ported the Greddy intake Mani
redirected IC piping
and did some loom work
It looks like its coming together nicely.. even if it doesnt run well from sitting for so long its still gonna look pretty
- DriftZ
- Car: S15
been working on the SX long and hard for the past 3.5 weeks here a list ( what i can remember ) of whats we've done...
PS: big thanks to Poizn for coming around a couple times to help out, and for his amazing alluminium weld work on my intake manifold.
1. Solid steering bush
2. Greddy intake manifold.. lots of work to make this work / fit
3. New clutch MC
4. 800cc injectors tested - 100% perfect
5. fit Kouki Tailights
6. fit Stainless brake lines
7. re-route rear hard brake lines
8. Fit alli pully's
9. fit radiator breather tank
10. fit new Power steering tank
11. remove heater water pipes
12. fit blue radiator pipes
13. get new water temp sensor
14. fit oil temp guage
15. fit new remote oil filter + cooler kit ( what a mission )
16. remove Gotech
17. install Haltech ECU
18. install new FPR
19. install Greddy fuel rail
20. install new Devils Own Progressive WM kit ( work in progress )
21. install Surge tank ( work in progress )
22. fit Magnetic Sump plug
23. re-route oil Breather pipes
24. source TPS - fit
25. match port Greddy manifold to suit new TB
26. re-route IC piping
27. install distibuter
28. fit rear urethane bushes
29. fabricate under nose spoiler / tray for better aero..
30. new air filter, oil, water, bleed brakes and clutch...
.. I still have a couple things left...
flip intercooler
remove remaining tar from passenger and drivers areas - with dry ice
fit D2 Seat belts
fit drivers bucket seat (using my PS3 bucket seat - untill i can afford a proper seat
fit Wideband Gauge and sensor
fit thermal manifiold spacer
fit new remote fuel pressure gauge
... then we'll hold thumbs and turn the key.
wheel alignment
tune
dyno run
3. New clutch MC
8. Fit alli pully's
16. remove Gotech
18. install new FPR
flip intercooler
fit D2 Seat belts
wheel alignment
tune
dyno run
