Upgrades on 200sxrb25
- 200sxrb25
- 0.2 Bar Boost
I started my upgrades on my rb25. Took of the exhaust header, to cut out flanges for top mounted turbo.Planning to build my own header. Fit the gfreddy intake,but the master cylinder is not going to fit. My rb is about 40mm from my firewall, an my sump is on the cross member. Is my sump my problem ,or what can i do to get it right?
200sx rb25
lotus 7
lotus 7
- RB25SX
- Car: R32
think u used the shorter fat box, wich makes it very difficult to move the engine forward. We used the longer box to have the engine a bit forward and get the gear lever in the right place. Best is to cut a piece out the back of the intake and weld a plate over to make it fit. It was done like that on Rudeboy's RB S13.
R32 GTR
- 200sxrb25
- 0.2 Bar Boost
Upgrades
I have a AC/DC tig welder, i can weld it myself.RudeBoy wrote:what Wynand said - get the intake mod done - just find someone that can weld ally
![Smile :)](./images/smilies/icon_smile.gif)
200sx rb25
lotus 7
lotus 7
- RB25SX
- Car: R32
Re: upgrades
sounds like a good price.200sxrb25 wrote:What is a good price for a fatbox? I can get one for R5000.
R32 GTR
- 200sxrb25
- 0.2 Bar Boost
Upgrades
Need some info...
Talk to a guy from rover tech from mosselbay at the drags held at killarney. Rudeboy do you know that guys of rover tech? He told me that you must weld in a baffle plate in the greddy intake, to change the air flow. He say that the no.1and2 intake ports draw more air. Is you guys aware of this?
200sx rb25
lotus 7
lotus 7
- 200sxrb25
- 0.2 Bar Boost
upgrades
The engine is out and cleaned. Under the intake manifold is there two green censors, what is the function of that censors? The clutch is no more, the fly wheel need to be skimped. Is the v6 hard body clutch going to work on the Rb? Going to make up a button clutch,but need the pressure plate.
200sx rb25
lotus 7
lotus 7
rb
as far as i now the hardbody v6 clutch works.but if u in cape town take the flywheel and old clutch to ferobrake in epping,and have them build the clutch u want. if its a track toy the double diaphram button clutch will be able to be made up for u .thats waht i had for my r33 but if u plan to drive it around as a daily then button with single diaphram will be less painfull in traffic. make sure you tell them wat your intention for the clutch is after a year of abuse my clutch still loked good wen i took the motor out.
sideways forever....
- RudeBoy
- 0.5 Bar Boost
Re: upgrades
how much of a hurry you in? - i might have my rb26 clutch for sale soon, still in pretty good nick, will take some pics tomorrow200sxrb25 wrote:The engine is out and cleaned. Under the intake manifold is there two green censors, what is the function of that censors? The clutch is no more, the fly wheel need to be skimped. Is the v6 hard body clutch going to work on the Rb? Going to make up a button clutch,but need the pressure plate.
from what ive seen the rb25 and the early rb26 push style clutch kits are the same... p.s the one i'm removing is a unsprung 4 puk with a pretty new valeo pressure plate
- 200sxrb25
- 0.2 Bar Boost
Upgrades
@Godzilla: Yes i going to use it as a dailey and drags, gymkhana,top end runs.
@Rudeboy:I am not in a hurry, got to do the suspension bushes,header and i going to take my time on the job.
200sx rb25
lotus 7
lotus 7
- 200sxrb25
- 0.2 Bar Boost
[img][img]http://i852.photobucket.com/albums/ab81 ... C12857.jpg[/img]
Test fit the intake and turbo.
[/img]
200sx rb25
lotus 7
lotus 7
