S13 RB25 Back From The Dead......
dialate
Post by dialate »
nirvash wrote:drifting with that much power must be insane :twisted:
havent tried yet, but will take video :)
Im pretty sure it'd be fun most of all.. lucky bugger :)
dialate
Post by dialate »
DriftZ wrote:Im pretty sure it'd be fun most of all.. lucky bugger :)
welcome to take a suicide ride
Always been keen to die smiling :)
SlowMo
Post by SlowMo »
wow that is some crazy power there dude!!! well done :D
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
dialate
Post by dialate »
SlowMo wrote:wow that is some crazy power there dude!!! well done :D
thanks man, its awesome!
Lindt
Post by Lindt »
Where does the feed from the bosch pump come from, surge tank?
dialate
Post by dialate »
Lindt wrote:Where does the feed from the bosch pump come from, surge tank?
nope, theres just one pump, no surge or primary pump and linked straight to tank..
Lindt
Post by Lindt »
you mean you're running a bosch pump above fuel level without grafity feed at least, ok, that's suicide
poizen
Real Name: Mical Mackay
Post by poizen »
Lindt wrote:you mean you're running a bosch pump above fuel level without grafity feed at least, ok, that's suicide
true rather invest in a surge take with tat expensive motor its the least you can do
FUEL PERFORMANCE
Post by FUEL PERFORMANCE »
True , for that motor & money inside I would run a Internal pump feeding a small Surge Tank and 1 or 2 External pumps feeding the motor.
But then again 1 Internal HFP 255LPH Pump can feed up to 600HP ! 8) :lol:
FUEL PERFORMANCE SA-UK-EU
HIGH FLOW SA-UK-EU
poizen
Post by poizen »
350Z wrote:True , for that motor & money inside I would run a Internal pump feeding a small Surge Tank and 1 or 2 External pumps feeding the motor.
still have a small chance it will suck dry as most sx owners drive with the petrol light on
surege tank is a piece of piss to make go to nearest engineerign shop i say max 3hours making it so you looking at under 1k for it then yout low pressure pump to the tank and high pressure out you will want mayb 2-3liter storage in the tank least then you never risk that chance
i mean what is 3k compared to a 50k+ motor
dialate
Post by dialate »
guys i hear you.. and now that you are all finished telling me how im on a suicide mission.... we are installing a surge system with the walbro that was in the car originally, this is a temp measure, just set it up like this to dyno the car.
Bear in mind, i dont drive this car every day, its definitely a track / drift vehicle.. and will have all the goodies in place to support this.
my opinion - anyone that spends over R100k to build a motor like this, and then rides around with the petrol light on, is a tool.. end of story ;)
[/i]
dialate
Post by dialate »
the 044 can pump 600 litres an hour.. its like having 2 and a half walbros.
RB25SX
Post by RB25SX »
dialate wrote:the 044 can pump 600 litres an hour.. its like having 2 and a half walbros.
Quoted from the bosch pump suplier site:
Bosch 0 580 254 044 Inline Fuel Pump
Bosch 044 fuel pumps mount inline (out side of your gas tank), most commonly rear center under your car or truck. Each Bosch 044 inline fuel pump provides 300LPH of flow and operate at 72.5 PSI. Bosch 0-580-254-044 fuel pumps are comparable to the Walbro 255LPH high pressure inline fuel pumps which can both support vehicles for up to 600-700 horse power. Can be used in sequence with an intank Walbro or Bosch 040 fuel pump.
R32 GTR
