djtreble wrote:Yeah that's why I said they are all ball bearing, which makes me think they don't make the standard t25 anymore (ie. non-ball bearing)
i dont think so hey new techno has taken over
just put up a add and ask for one like i say pm riekert he can get you a t25g which is a better version than the std t25 it has the same size exhaust but it has a larger compressor side so flows more
i make 140kw with that turbo at 0.9bar boost with basic bolt on's and std ecu
Hi Guys, I found someone in Pretoria that sells a T28 Garrett for R3900- and apparently only the downpipe should change (Downpipe = R140-)
It is'nt a ball bearing turbo though....
Does the pricing sound right or could you direct me to any other sellers?
Well if it's new and you base the price on the Autostyle turbo you were looking at, I'd say its good. I'm only really aware of price in the UK and they sell for £150 second hand.
You don't need to replace the elbow, you just have to widen one or two of the bolt holes with a round file/dril bit. I've done it before and is a much cheaper option with no detremental effects. Also remember to widen the gasket's hole...I just widened all of the holes so that I didn't have to fettle with that and I could concentrate on the elbow.
Just remember you will have to run the boost lower of running standard parts and standard ecu
djtreble wrote:Well if it's new and you base the price on the Autostyle turbo you were looking at, I'd say its good. I'm only really aware of price in the UK and they sell for £150 second hand.
I'm running aftermarket feul management with stock internals.
Thanx for advice.
djtreble wrote:Yeah then all you will need to do is adjust accordingly. You will notice a big difference between the t25 and t28 and if you can afford it...do it!
yeah! there is quite a difference between the two. I did the upgrade on my buddies car. and it was really really nice
