Hi guys .....
Im in need of advice!!!!
standard ca18det with standert management just changed turbo to T3T4 now the car can bearly rev up and if it does its like the timing is retarded very very slow......... PLZ help im losing my mind cant find the propblem
.. and is thier a boost sensor on the intake by any chance
Thanx
slow reving
BOOST ADICT
BOOST ADICT
- poizen
- Real Name: Mical Mackay
ok so manifold was built for the t3t4 ok then that points to your intercooler
its on the small side for t3t4 you need about a 600x300x76mm intercoler or even a 600x150x75
hows your timing have you checked it and made sure its on 15 deg
on you cas (located on the front vaulve cover) it has 3 slots where its bolted into the cover are the bolts in the middle or to the right or left
if on 15deg should be in the middle
so many things where you from so mayb someone can come help you
BOOST ADICT
