OEM Fit for all makes of Vehicles
HFP Intank Pump 255LPH - R1180
WALBRO External Pump 255LPH - R1300
Mail For Info & Details!
Thanks!
Quick Overview
A World Class cost effective replacement for a host of High Performance 255LPH pumps that will help you maximize the POWER of your vehicle's modified or stock engine...Product Description.All HFP Brand fuel pumps are QS9000 certified and feature a one year replacement warranty. Similar to Walbro in design and flow, our pumps are efficient, quiet, and long lasting. Able to maintain high pressures while sustaining the high volumes that high horsepower motors require. A number of advantages have been designed into our pumps which are not found in other high flow 255lph fuel pumps. Notably, these pumps are significantly quieter. Instead of the vibrating hum that is usually associated with aftermarket performance fuel pumps, our pumps produce a very faint "wheen" sound during priming (when the key is first turned on) and are virtually SILENT when the engine is running.
HFP Brand fuel pumps have been designed to perform reliably for years to come under high horsepower as well as unmodified daily driven vehicles. Suitable for turbo, stroker motor, blower, or nitrous applications, they can also be used as OEM replacements. The advantages of modern return-style fuel systems are that they only use as much fuel as they need. Any unused fuel is sent back to the fuel tank via the return line. Our fuel pumps support up to 600hp.
Specifications
HP Rating: Up to 600hp Design: Intank Flow: 255LPH High Pressure Minimum Voltage: 12V Operating Pressure: 35-100psi (Final fuel pressure determined by your fuel pressure regulator) Includes Installation Kit with Strainer
Warranty
All HFP Brand fuel pumps come with an industry first 1 year FREE replacement warranty. If at any time within one year of your purchase date, your fuel pump should fail for any reason, simply contact us via phone or email and we will exchange the pump free of charge.
