can some one confirm if sa 200sx have the drum hand brake at the back?
My jap 180sx the hand brake cable goes on the caleper
thanx
rear brakes
- Real Name: Renier
rear brakes
She is the CA that IS
(O=O)/RS13\(O=O)
"EVERYDAY I'M FLUTTERING!"
- Skylinefreak
- 0.5 Bar Boost
- Real Name: Renier
a haa so nissan sa must have changed it basicly r32 rear hub setup.
it had my head in a spin coz i remember faintly that the hand brake cable goes into the back plate thing.
that makes the 2pot brake conversion so much easier at the back.
My 180sx handbrake locks caliper and rears are the same on s14s15 but fronts are s13 sr brakes with 280mm discs
any idea on the size of the rear discs and the size of the drum?
(O=O)/RS13\(O=O)
- Skylinefreak
- 0.5 Bar Boost
- Real Name: Renier
ok so for the guys that did z32 rears.
Did the z32 discks work with the stock rear hand brake asembly?is the in ternal drum the same size?
With the z32 discks fited does the rear caliper bolt up to stock mounts?
I am planing on using alloy r33 calipers and discks
fronts 296 by 30mm
rears 297 by 18mm
thanx
fronts 296 by 30mm
rears 297 by 18mm
thanx
(O=O)/RS13\(O=O)
