my S14 went into anti-thief mode? how do i get rid off it?
take the security system off??? or diconnect the battery will do???
anti-thief mode?
You can't run the car without the NATS if it came from factory that way. The NATS system is about the hardest system to crack.
You'd need to replace the ecu and ignition among a few things
Are you unable to start your car? What happened that got you in this now?
I will have a word with a few people and can maybe help you
- aep886
- Car: S14
- Real Name: Davey
it cut off the starter to the pumps... unable to start the car... battery is not cut off.... ><djtreble wrote:You can't run the car without the NATS if it came from factory that way. The NATS system is about the hardest system to crack.
Make sure the battery is fine (ie replace it temporarily), the check all the fuses. Then check all wires with a meter to make sure it's all getting power.
If you are unable to find teh problem, the best bet is to go to an auto electrician.
Is it doing absolutely nothing? Ie not even turning over? Can you hear the fuel pump priming?
- aep886
- Car: S14
- Real Name: Davey
^^ thanx bro ... i find the problem ... starter is fucked not the alarm...djtreble wrote:Make sure the battery is fine (ie replace it temporarily), the check all the fuses. Then check all wires with a meter to make sure it's all getting power.
coz i push start the car and it goes... now time to sort out the starter
recon the starter... R500 +-aep886 wrote:^^ thanx bro ... i find the problem ... starter is 000000 not the alarm...djtreble wrote:Make sure the battery is fine (ie replace it temporarily), the check all the fuses. Then check all wires with a meter to make sure it's all getting power.
