Which SR20 cranks can be used in which block??
n1smo200sx
Post by n1smo200sx »
Which Sr20 cranks is the same?
Can the Redtop Sr20DET be used in a Black top ?
Can a FWD SR20DET be used in a RWD SR20DET?
Is the flywheels of the FWD NA SR the same as RWD SR20DET?
i know the GtiR cranks has wider bearings,so cant be used.
Anyone?
fwd and rwd are different i think but red to black tops the bottomends are the same
The vvt journals are wider i think 19mm suppose to 17mm of the red and block top non vvt.
n1smo200sx
the Gtir is 19mm
n1smo200sx wrote:the Gtir is 19mm
So are yours?
n1smo200sx
Anyone with some knowledge about this?
Phone Koos he just did the exercise recently.
Lindt
Post by Lindt »
you building a spare motor or did yours break
n1smo200sx
Spare one,need a stock crank.dont want a cut crank
aep886
Real Name: Davey
Post by aep886 »
FWD crank wont work on the RWD block
djtreble
Post by djtreble »
As above.
And yes a redtop and blacktop rwd cranks are the same
www.rotawheels.co.za
www.kaihatsu.co.za
