I also use a ajusa head gasket and ARP bolts on my RB30DET, and it holds up fine to 1.2 bar. They have gone 1.5 bar on those gaskets, with RB30. (R550 from masterparts)VeNoMiZeR wrote: gunna strip and order a ajusa headgasket and arp head studs hope that will solve the problem..
Project VenomZR
adjuza works wonders, we all used them on the 7m's. Even up to 2bar boost they hold.VeNoMiZeR wrote:Drove 400km with the z and the sh!t toyota broke.. blew headgasket after block is o'ringed.. gunna strip and order a ajusa headgasket and arp head studs hope that will solve the problem..
- Highboost
Hey dude sorry to hear of your misfortune
I had simmilar problems with a 7MGTE
If your intrested you can buy my 7mgte bottom end ( 2 melted arias pistons 4 still in good nick), R154 supra G/box, flywheel, 2x heads with
cams 3x sets of tappet covers , 2x turbo manifolds, 2x intakes with throtle
bodies, 1 x distributor modified to use hall sensor PLUS A SET OF ARP headbolts.
PM me, its a bargain.
- VeNoMiZeR
- 0.2 Bar Boost
After removing the head and found the gasket blew on numerous places, ive opted for a Ajusa steel headgasket.. after months of search for one found one lol
now just need my ARP studs then i can assemble again..
Soon boosting 1.0bar
Current: 93 Pulsar SSS N14 Japspec (in Progress)
Ex:Nissan 300zx z32
Nissan S13 200sx SR20det
Nissan Sentra 200sti Neo Vvl
Nissan 200zr RB25det
Nissan 300zx z31 Vg30et
Ex:Nissan 300zx z32
- VeNoMiZeR
- 0.2 Bar Boost
got a update... Got the ZR up and running again! Yay this time im hoping it would last. Ajusa headgasket, ARP studs, and decent torque of headbolts.
Still running on 0.7bar boost.. will put the boost controller in this weekend and play around to bout 1.0bar boost
Tempretures are much better boosting going to 90degrees celcius and cooling down again.
Will take some pictures of interior this weekend once controller is fitted...
Ex:Nissan 300zx z32
Ex:Nissan 300zx z32
- VeNoMiZeR
- 0.2 Bar Boost
since the 7m only lasted this time 2weeks again.. think its time to pull the motor and open it again. noticed a small water leak found that the block has cracked on the side of the cylinders after pushing out the welsh plug today
Ex:Nissan 300zx z32
Ex:Nissan 300zx z32
