Headlight
Headlight
So....I've had a problem since I got the S13.....
the right hand side(driver) headlight works, when you put it on bright it goes off, the left hend one works fine, I checked fuses and all....unless there is fuses or relays I don't know about....checked the manual....but I am not a electrical picture boffen......so that did not help me at all...
help?
help?
- ljS14
- Car: Evo
- Real Name: Shane
Had this problem on my S14,Took it to the auto elec and my SWITCH was faulty,These cars are complicated and run parellel on the switch for the lights(or somthing like that
He fixed it while i was waiting,Thought i was going to have to buy another switch but its simple if you know what you doing
I dont thats why my local Auto elec helped me.
1991 S13 200SX
1993 Z32 300ZX Convertable
Evo 8
Evo 8
Ok....I have sorted it.....
If you take the whole switch out there is the almost see through cover on the back, take it off, there is 5 copper plates, when you put on the lights the middle one goes down and makes contact with the 2 right ones, when you put on the brights the 2 right ones go up and the 2 left ones goes down....if eather one of them don't make contact your brights won't go on or off
PS....sides mentioned is when copper plate contacts show towards you.
