HELP WITH PICS (RB25DET GUYS)
- westmaister
DOES ANYONE HAVE PICS & SOME INFO ON THE BRACKETS YOU NEED FOR THE RB25DET CONVERSION? ANYTHING WOULD BE HELPFUL!
BEERS & SEXY REARS!
rb
dont want to hijack your post but i am looking for the part that mounts to the motor?!?!!?anyone or the pics and details how to make one,dont really wanna make a template and then drill and then weld etc.....
sideways forever....
- RB25SX
- Car: R32
I just built some new ones for RB30, but welded the extension mountings onto the crossmember.
The mountings that go onto the block are not all the same. in the pic is a alum. RB26(right) and a steel RB30(left), and RB25 alum. ones are also differant. The holes on the block are the same, but then rubber mounting position is differant.
R32 GTR
- westmaister
- RB25SX
- Car: R32
Mountings from Rubber products and mouldings in CTN. Yes, the block is not the same angle on both sides.westmaister wrote:THANKS BUD! WHERE DID YOU GET THE ENGINE MOUNTINGS FROM?
IS THERE A DIFFERENCE IN THE ANGLE WHERE THE ENGINE MOUNTING CONNECTS THE ENGINE/ENGINE BRACKET TO THE CROSS MEMBER?
R32 GTR
- westmaister
IF YOU DONT MIND, WHAT DO THEY COST & ARE THEY DURABLE/GOOD QUALITY?RB25SX wrote:Mountings from Rubber products and mouldings in CTN. Yes, the block is not the same angle on both sides.westmaister wrote:THANKS BUD! WHERE DID YOU GET THE ENGINE MOUNTINGS FROM?
BEERS & SEXY REARS!
- westmaister
mountings
hey nice work there. those solid mountings are really good.The std r33 ones i had tore cause they are oil filled I ended up having solid ones made up,also at rubber products in kengsington .on another forum i saw a cheap alternative,the stack 2 ice hocky pucks on either side, some wide washers and drillhole throu them using some thread bar( the strong stuff) instead of the ubber expensive nismo mountings.pity we dont have ice hocky here heheeheh.ill have a scout around for some rb30 mountings ....
