hi guys
im thinking of fitting electrics fans
anybody have ?? and for how much and is it a easy install ?
Electric fans wanted
Driftmeister
- 0.4 Bar Boost
if you can drive it drift it
mmm... you think my father would mind if I steal his BM's fan?Charlvdw wrote:E46 radiator fan sucks leaves of the curb as well.Riekert wrote:after SR swap fitted a 12/15" fan, works wonders car runs super cool
Driftmeister
- 0.4 Bar Boost
- Charlvdw
Your lower radiator pipe on the ca is were you should put the fan switch which will trigger a relay which in turn will switch your fan on. Get a switch that switches on at 89' + - and off just below 80'. Any decent radiator shop should be able to supply you with the t-piece which fits into your lower pipe for the switch.Driftmeister wrote:ok so should i go electric ?
and mods? for the fan switch ?
As far as i know the sr comes with a switch in the block. Turbo side front below the head.
Driftmeister
- 0.4 Bar Boost
