Rear suspension noises
Driftmeister
Post by Driftmeister »
hi guys
im picking up a noise on the rear suspension
like something on the spring
do u think my rear shocks are pomped ?
if you can drive it drift it
ReeceZ
Post by ReeceZ »
can u describe the noise, i get freaky things happening in the back as well :?
is it squeaky, high pitched squeak, creaking sounds...
ReeceZ wrote:can u describe the noise, i get freaky things happening in the back as well :?
bushes?
Speed breeder
0.7 Bar Boost
Post by Speed breeder »
Easy to test shocks and should be free to test (no harm going to a fitment centre and letting them have a look)
Check to see if all bolts on the top shock mountings are fastened
Check for leaks on the shock
And after all that - check out the rear bushes like rat said.
You won't believe how many bushes are on the rear suspension :shock:
Driftmeister
cool will do thanks guys
