RB20DET Motor - R5500
- FUEL PERFORMANCE
Engine
Type (see below) RB20DET Twin cam, in-line 6, Turbocharged
Displacement 1998 cc
Compression Ratio 8.5:1
Max. Power; kW/bhp 160/214 @ 6400 rpm
Max. Torque; Nm/ft-lbs 263/194 @ 3200 rpm
Bore x Stroke; mm 78 x 69.7
Redline 7600 rpm
Fuel Injection Nissan EGI (ECCS)
gearbox
Transmission 5 speed manual
Gear Ratios
1 3.321
2 1.902
3 1.308
4 1.000
5 0.759
Reverse 3.636
Redline 7600 rpm
gearbox
Gear Ratios
1 3.321
2 1.902
3 1.308
4 1.000
5 0.759
Reverse 3.636
FUEL PERFORMANCE SA-UK-EU
HIGH FLOW SA-UK-EU
HIGH FLOW SA-UK-EU
- FUEL PERFORMANCE
BUMP.........................I want to fit my RB25DET!
someone buy the RB20DET!
HIGH FLOW SA-UK-EU
HIGH FLOW SA-UK-EU
- FUEL PERFORMANCE
RB20DET will be out this week & Ready for Shipment!
BUMP
BUMP
HIGH FLOW SA-UK-EU
HIGH FLOW SA-UK-EU
Driftmeister
- 0.4 Bar Boost
- FUEL PERFORMANCE
acemine I PM'ed you Back.
HIGH FLOW SA-UK-EU
HIGH FLOW SA-UK-EU
- FUEL PERFORMANCE
Motor & Gearbox Out and Ready to go.
R10K
BUMP!
R10K
BUMP!
HIGH FLOW SA-UK-EU
HIGH FLOW SA-UK-EU
- FUEL PERFORMANCE
Had the Head checked/Cleaned & new studs put in.
All 100%, will fit back later.
Pistons & Bore are Perfect aswell!
HIGH FLOW SA-UK-EU
HIGH FLOW SA-UK-EU
- FUEL PERFORMANCE
Gearbox **SOLD**
Motor - R6000
Motor - R6000
HIGH FLOW SA-UK-EU
HIGH FLOW SA-UK-EU
- FUEL PERFORMANCE
R5500
HIGH FLOW SA-UK-EU
HIGH FLOW SA-UK-EU
- FUEL PERFORMANCE
R5500 Including Delivery
HIGH FLOW SA-UK-EU
HIGH FLOW SA-UK-EU
