Branch and Free Flow
KCSX
Post by KCSX »
sup guys , i just got a quote for a custom branch and free flow exhaust for R2850, is that a good price, i got the quote from Kwik fit
Speed breeder
0.7 Bar Boost
Post by Speed breeder »
free flow = 2 silencers vs a standard 3.
on a turbo car you only need a back box really unless you want a fairly quiet car
to answer your question price seems good considering they are giving you a branch or manifold.
mild or stainless system and what size xhaust?
not to bad... but why the branch?
you need a downpipe for the turbo and then the exhaust.
Also whats the size? 63mm? 76mm?
KCSX
Post by KCSX »
its a 52 mm exhaust, wouldnt a branch give me more power
KCSX wrote:its a 52 mm exhaust, wouldnt a branch give me more power
We are talking about a SX exhaust here right?
KCSX
Post by KCSX »
ya , why , i new 52mm seemed a bit small
yeah the stock one is 52, so you wouldn't gain anything. and a branch will only work if you don't have a turbo on the car.
So with that... the R2800 is way to much to pay for that system. You need at least a 63mm exhaust, and you don't need a branch.
I got a qoute form HiQ for R1300 for a 63mm freeflow. and I supply my own downpipe.
So I think shop around a bit more.
You should be able to get a full 76mm exhaust for around R3k
76mm! 2 box if you want it quiet, 1 box most people go for. And try for a down pipe as well. Manifold equal length would be nice but if you still running the std turbo i don't see it making much difference
KCSX
Post by KCSX »
which would give me the most gain? 63mm Or 76mm
76mm do it right the first time. Will help for any bigger mods later
Trance101
Real Name: Ryan
Post by Trance101 »
KCSX wrote:which would give me the most gain? 63mm Or 76mm
76mm, with turbo cars less restriction is best.
Jip... Like the two above me said... :twisted:
Speed breeder
0.7 Bar Boost
branch (some people call the turbo manifolds, turbo branches) will also have gains, even on standard turbo as long as the flow is better than the previous setup...thus creating greater velocity at lower RPM improving low end torque and responsiveness...
there is no guarantee though seeing its a custom "branch"/manifold...
as previously stated, make sure the guys at this place know what an SX is first...
this topic including pricing has been discussed a couple of times and prices for just the exhaust including downpipe range between R1200 to R4000 depending on what system is chosen. (R4000 being the stainless 76mm pipe) - thus excluding the manifold
THEO 3K - ZN
Post by THEO 3K - ZN »
Std sx down pipe is 63mm, right?
f thats true, then can you put a 76mm exhaust flanged to 63mm down pipe?
Or must you change the down pipe to a 76mm?
CARBON BLACK MILLIONAIRES CLUB
MITSUBISHI TRITON 2.4 + VAT
200SX - 1.8T
OPEL CORSA UTE
MK1 GOLF - 2L 8V
GENERAL TURNING & MILLING
THREAD REPAIR & STUD REMOVAL
QUEENSBURGH TRADING
KCSX
Post by KCSX »
so guys i really dont need a branch manifold , what about one those top mount manifolds i keep hearing about , would one of those give me more power?
