SR20DET for sale
Wanted or for sale
Locked
SYMC
Newbie
SR20DET for sale
Post by SYMC »
SR20DET Red Top (non-VVT) with RWD gearbox for sale. Includes new gasket kit.
Any offers? [/img]
i see you tried to post an image.
hopefully you get that right
[img]put%20your%20image%20link%20here%20between%20these%20two%20thingies[/img]
also, we could banter prices around for a long time without coming to a conclusion.
how much would you like for the motor and gearbox and kit???
thanks
vc
widowmaker
Real Name: Walter
Post by widowmaker »
is this the one that was advertised a while back ?
came out of a kit car or lotus7 or sumn?
anybody : is it the VVT-part that ive heard that gives trouble on these engines? does that mean the non-VVT engine is the better one then?
(sure, maybe slower, but will last longer?)
The Calibrator
Post by The Calibrator »
Red top is non VVT
there is a blacktop without vvt.
then there is the sloping blacktop with vvt!
Dislex666
Post by Dislex666 »
and the VVT doesn't give kak - it just makes a noise sometimes
Sokar
1.0 Bar Boost
Post by Sokar »
veecee wrote:then there is the sloping blacktop with vvt!
A.K.A the Hump-back, I wish I could speak whale....
Dislex666 wrote:and the VVT doesn't give kak - it just makes a noise sometimes
And sucks your sump dry, and makes you run a bearing and makes you spend alot of money fixing stuff the previous owner stuffed up, and and and... :P
Captain Slow to the rescue!
Dislex666
Post by Dislex666 »
wtf are you smoking?
how can VVT make you run bearings?
Sokar
1.0 Bar Boost
Post by Sokar »
Dislex666 wrote:wtf are you smoking?
Its just what I've heard man, the VVT uses oil and oil pressure so its taking oil away from the sump, I'm sure it a number of other factors but the main thing seems to be, if it was a normal blacktop/redtop it wouldnt have happened...
But hey, what do I know, I just fly the thing :P
Dislex666
Post by Dislex666 »
nee fok boet...
the 'oil' the VVT uses is just for hydraulic purposes, ie. to actuate it.
So if THAT makes your sump run dry, then you should try run with more than 2 pints of oil in the car :D
Sokar
1.0 Bar Boost
Post by Sokar »
Dislex666 wrote:So if THAT makes your sump run dry, then you should try run with more than 2 pints of oil in the car :D
True that!
widowmaker
Real Name: Walter
Dislex666 wrote:more than 2 pints
why drink and drive if you can smoke ganja and FLY!
Locked
