CA18DET stroker kit
Andrew.200SX
CA18DET stroker kit
Post by Andrew.200SX »
Hi guys
In an older Speed & Sound mag they mentioned that you can get a "Kit" to take the CA18DET from the 1.8 up to a 2.2 , does anyone know anything about this?
Yes I think Tomie makes it, about R20k though.
Andrew.200SX
EINA !! :x
ReeceZ
Post by ReeceZ »
There goes that plan :lol:
ReeceZ wrote:There goes that plan :lol:
lol
Pinkfluffybunnys
Real Name: Ashley
Post by Pinkfluffybunnys »
Well Not really, there was two kits one from Tomie the 2ltr stroker and one from Jun the 2.2 liter stroker.
You can’t use a CA20E crank in a CA18DET block because the crank journals are to smaller then the CA18 crank but you can fit a CA18DET Head onto a CA20E block its very much the same as the RB30DET build but the head bolts and timing belt need to be sorted there is a guy in Germany that I email every so often that does this swap but I have never asked or see pictures.
But he does say the Ca20E is an overall weaker set-up stock for stock then the CA18DET but he does say the forged CA18DET pistons can be used and he can get eagle to make custom con-rods he also says the low down tourque is amazing but the CA20E flywheel needs to be used and the CA18DET clutches modified
1\4 Mile:
Because Race Car
Pinkfluffybunnys
Real Name: Ashley
Here is a guy that’s done it
http://members.optusnet.com.au/~web101/s12.htm
But you could go the route that was suggested to me after I rebuilt my damn motor you can have the Smaller journals of the CA20 crank metal stitched up and polished to match stock CA18DE size but then you will still need the custom conrods to my knowledge I might be wrong
Also I forgot to add if you do the CA20E bottom end you will need to tap the block for the idler pull, plus tap for the oil squirters and take the crank girdle over as well also im not sure if you can beep the air-con and AC I didn’t ask
Also norries sells a stroker crank for R18000
1\4 Mile:
Because Race Car
Andrew.200SX
I can allways rely on you Mr. Pinkfluffybunnys to get me the correct information.
Thanks again
Just for interestsake, whats the biggest oversize pistons you can use in the ca18?
Pinkfluffybunnys
Real Name: Ashley
Im assuming you mean before getting to close to your water channels becomes an issues to be honest I dont know.
But I know the normal over size is 84mm
1\4 Mile:
Because Race Car
I cant remember the math ,to what cc will that take you?
Pinkfluffybunnys
Real Name: Ashley
I stand to be corrected here but if my math is right 1853cc
1\4 Mile:
Because Race Car
Pinkfluffybunnys
Real Name: Ashley
Alright Guys who wants to build SA's first CA20DET ?
I got the inside info from a friend.
What’s needed?
* CA20E Block
* CA20E Crank
* Mistu 4G63 (First gen Conrods) -Must be the narrow big end good for 400HP
* Custom Pistons from Aries - (84.5mm) or B20\CRV pistons fitted with a B16 head (Guy says these are common off the shelf stuff where he is)
* Crank Girdle - Use the Ca20E caps but the CA18DET Bolts will fit
* CA18DET Oil Pump
* Custom Cam-belt - has to be custom made not that expensive
You will need to tap the CA20E block in the same place as the CA18DET idler pulley drill to 8.6mm and tap to m10. You can use the stock CA20E flywheel and CA18DET Clutch.
The guy recommends ARP head bolts the set-up is good for 400 HP but does not Rev as good because of the longer stroke around 88mm
1\4 Mile:
Because Race Car
RB25 FTW!!!
Gary57 wrote:RB25 FTW!!!
Ditto!
