Posts: 5378 Joined: Sat Jun 30, 2007 10:38 am
Post
by rat » Fri May 08, 2009 11:55 am
Why mine keep blowing, head to mani and mani to turbo.
i have tried pirate and Nissan gaskets
hentiebez
Posts: 430 Joined: Wed Oct 01, 2008 4:39 pm
Post
by hentiebez » Fri May 08, 2009 12:09 pm
check with Mical (Poizen) he had some copper one's made and he is selling them off
hentiebez on Fri May 08, 2009 12:48 pm, edited 1 time in total.
Posts: 5975 Joined: Thu Oct 12, 2006 12:56 pm
Post
by Gary57 » Fri May 08, 2009 12:11 pm
Not fitted correctly?? Manifold is warped??
Try listening to me AND DONT USE GASKETS!!!
Posts: 7354 Joined: Wed Nov 08, 2006 3:49 pm
Post
by veecee » Fri May 08, 2009 12:31 pm
weld the manifold to the head!
if that doesnt work then make a manifold from aluminium and weld that to the head. make sure its heat resisitant aluminium
Posts: 2078 Joined: Fri Sep 21, 2007 10:18 am
Post
by Drillergy » Fri May 08, 2009 12:42 pm
Either your mani or head (@the Exhaust outlet) is warped. Try skeeming it.
Also check water temp, radiator cap as well.
And then fit Copper gaskets
If you have an aftermarket manifold then its probably that.
My 2c.
Posts: 5723 Joined: Thu Aug 03, 2006 8:32 am
Post
by Draco » Fri May 08, 2009 1:39 pm
No one believed me back then....ask Freddy...I used normal clear selicone on my cheapy gasgets....and with SS....never blew....
Obveously the experts won't agree....granted...if you have an warped item...nothing will work...
my 1/2 a cent.
Post
by veecee » Fri May 08, 2009 1:46 pm
copper gasket spray also works nice, but it has to be straight as an arrow mabroo!
Posts: 3882 Joined: Wed Jan 09, 2008 10:08 am
Post
by Charlvdw » Fri May 08, 2009 1:47 pm
Were do you get copper gasket spray?
Post
by Draco » Fri May 08, 2009 1:50 pm
Any spare shop...
Post
by rat » Fri May 08, 2009 4:51 pm
3000kms ago. Manifold skimmed and head checked by engineer, autozone gaskets and firegum, locknuts and spring washers.
Got nissan gaskets today look the same as the cheap ones just better cut :/
Post
by Drillergy » Fri May 08, 2009 7:45 pm
Change radiator cap, flush radiator and antifreeze. It could be a cooling prob.
ChemCool
Posts: 2195 Joined: Tue Aug 01, 2006 11:59 am
Post
by ChemCool » Fri May 08, 2009 7:53 pm
and around and around we gooo..
Post
by Charlvdw » Fri May 08, 2009 8:44 pm
rat wrote: 3000kms ago. Manifold skimmed and head checked by engineer, autozone gaskets and firegum, locknuts and spring washers.
If i could make a sugestion , dont use fire gum or gun gum ever. If you have to use anything use high heat silicone. Trust me on this.
Post
by rat » Fri May 08, 2009 11:27 pm
Charlvdw wrote: rat wrote: 3000kms ago. Manifold skimmed and head checked by engineer, autozone gaskets and firegum, locknuts and spring washers.
done 3 hrs to change them. used that silicone
NIZAN-R
Posts: 1201 Joined: Tue Jan 08, 2008 10:11 pm
Real Name: Renier
Post
by NIZAN-R » Sat May 09, 2009 8:35 am
After a week or so tighten the nuts again and then in two weeks time
She is not the
CA that could be
She is the
CA that IS
O = O )/
RS13 \(
O = O )
"EVERYDAY I'M FLUTTERING!"
