Right, So as you can see I have managed to organize us another trackday in KZN …….yes we’re back at Hesketh!!!! After a 7 month break !!!,YAHOOOOOOOOOOOOOOOOOOO!!!!!!!!
The day will run along the same lines as all the past Bunker Trackdays with 5 classes (max 10 per class) ranging from twin turbo full blown roll caged beasts in A class, to Reno Clio 1200mpi’s in E Class ……and no I wont put you Reno Clio drivers out in A Class .I want to encourage the novice to come and try out their cars out on a track, trust me it’s the best fun you can have with your clothes on!!!!....We will have instructors on hand to help everyone with the track lines, braking markers etc. ……So don’t be intimidated!!! The track has had all the grass cut and all run off areas cleared ,the track will be brushed the day before(by tractor!!)
I have to make it pre day booking only as I wont have the time to take cash in on the day and the less cash around the less chance of trouble. The entry form is attached so fill in and send it off and I’ll email/fax you the indemnity forms to fill out. If we can get all the paper work out of the way before the day the sooner we can all get on the track and the more time you will have out on it.
Format will be 6am sms to all drivers if the day will be cancelled due to rain in PMB,if it rains the trackday will move to the 16th May, if you don’t get the sms then the day is on. Drivers to be there 7h30ish for pit allocation, drivers briefing and scruitineering. A Class out at 9am followed by B,C,D,E repeatedly until lunch 12ish. Lunch will be bring your own meat etc I will supply the charcoal and braai. Track sessions will resume 1ish.R300 a driver for the whole day.
PLS IF YOU GO ON ANOTHER FORUM AND THIS IS NOT THERE PLS REPOST ON MY BEHALF ...shot !!!
If you need anymore info or have info for me please contact me:
083 6595 234
robprece@telkomsa.net
http://www.bunkerracing.co.za
Cya at the track !!
Rob
