350z wheels on a s14
neptune
Post by neptune »
Will the Oem 350z wheels fit on a s14, or do u need 2 modify it to fit?
poizen
Real Name: Mical Mackay
Post by poizen »
i know japspec has them on a s13 but he mush have 5stud hub im guesing from the s14 not sure but it is a nissin so the centers should be the same
neptune
Post by neptune »
Im mean the offset and stuff, otherwise i have to sell them again if 2 much trouble
Sokar
1.0 Bar Boost
Post by Sokar »
If you do want to sell, let me know, they will fit the RX8 aswell...
Captain Slow to the rescue!
Speed breeder
0.7 Bar Boost
Post by Speed breeder »
Sokar... you not selling the RX8?
5 x 114.3, 18" - 8.5j with 30 offset IIRC...
But if you have them, just fit them neptune and see if they clear. I think shock clearance will not even be an issue, it will just be body - but doubt that you'll have issues.
neptune
Post by neptune »
Speed breeder wrote:Sokar... you not selling the RX8?
I agree with you speed il just make a plan/ modify if I have 2.
neptune
Post by neptune »
This is the dimensions
Front
Offset: +30mm
Weight: 26.56lbs
Tire: 225/45-18
Rear
Offset: +30mm
Weight: 26.56lbs
Tire: 245/45-18; 265/35-18 will also fit
Speed breeder
0.7 Bar Boost
some guys in the US are running negative offsets on their rides, so i think with a positive offset you should still be good to go.
s14 pcd is the same as the Z33 so :)
Don't know the clearance on the front wheels for an S14, but I know with the S13 with my current setup (18" 35 offset) I cant go to 245, maybe 235/40/R18.
I would try as big as possible at the rear though.
neptune
Post by neptune »
pitty its not the anniversary edition wheels, but I phoned Nissan and the old spec ones like mine cost R10600 each. Nissan SA is smoking us.
Sokar
1.0 Bar Boost
Post by Sokar »
Buyers havent been forthcoming. If someone is interested I'll sell, otherwise I'll just drive it, I'm not struggling so there isnt a real need to sell other than saving for a house...
Speed breeder
0.7 Bar Boost
Anniversary wheels are nice - makes the wheel look bigger, like the fact that the wheel design starts deep in the centre and moves out towards the rim.
Speed breeder
0.7 Bar Boost
Rx8 is an awesome car - Jeremy Clarkson gave it a brilliant rating on one of his dvd's..gotta love wankel
your price was very good also... best of luck...
don't you have the edition where the wheels look similar to the Z33 anniversary wheels?
neptune
Post by neptune »
I will c if they fit and post some pics.
Im picking them up tomorrow.
Speed breeder
0.7 Bar Boost
Cool, will look at the ice/accesories section tomorrow - i see no-one wants to touch that section of the forum with a stick... :)
