ditto!! heheherat wrote:RB26 > Women
What do you need for a 350kW SR20DET?
- DriftZ
- Car: S15
350rwkw is a rather large number, sounds fancy, but why so much? Personally id rather have a well balanced, better breaking, lighter 150rwkw car than just a stock handling car with 350rwkw.
Dont focus solely on power, as Huge Expensive power = Huge expensive brakes & suspension and so on ... you can't or atleast 'SHOULDNT' focus on power over everything else!
Words from a wise man...350rwkw is a rather large number, sounds fancy, but why so much? Personally id rather have a well balanced, better breaking, lighter 150rwkw car than just a stock handling car with 350rwkw.
- ReeceZ
Yeah right, this coming from the guy whose car is the most modded SX I've ever seenDriftZ wrote:350rwkw is a rather large number, sounds fancy, but why so much? Personally id rather have a well balanced, better breaking, lighter 150rwkw car than just a stock handling car with 350rwkw.
- thekoukimonster
Hi there im currently building a sr20det to be good for 600hp plus, but the goal for now is 320rwkw !!
It all depends on the money you have, currently im buzy with the bottom end, R40000 and not finished yet!!
Darton sleeved block R10000
Manley I beam tuff rods R7000
Cp Pistons R6000
Arp L19 main bolts 265000psi R2000
Acl race bearings calico coated R2000
New oil pump R3000
Greddy oil pan R4000
Os giken twin plate clutch R9000
Light weight flywheel R 3000
And this is just the bottom end!!.
Cp Pistons R6000
New oil pump R3000
