Hi there, currently im building a fully modified S14 sr20det, can anyone tel me what kind of power figures i can suspect with a Turbonetics t3/t04e ballbearing, 0.63 ar 50 trim(exhaust), and stage3 blade compressor at boost levels of 1 bar 1,5 bar and 1,8bar boost ??
Stage 2 264degree brian crower cams.
the koukimonster, waiting in anticipation!!!.
Expected power figures t3/t4 Turbonetics??
- thekoukimonster
- n1smo200sx
- 0.5 Bar Boost
- thekoukimonster
- Speed breeder
- 0.7 Bar Boost
I think its best you try the turbo first and then start playing around with the cams... its a trial and error process, unless someone else has the same spec t3/t4 that you have and have already tried different cam profiles.
Pick the top end power and boost you'll be happy with... also you don't want a motor boosting 1.8bar for a day and that's it...
your question was posted regarding how much power can you make - in most cases low end torque will have to be sacrificed for top end power... can't have both, unless you're running displacement and forced induction
You also did not mention other planned mods like the fueling (management and injection) and also sorting the spark and then off course how you cooling the charge down.
- thekoukimonster
Im building it as strong as possible, sr20det bottom end Acl calico coated race bearings, , cp pistons, manly conrods, arp studs etc.
For now i dont plan on making more than 320wkw but im building it to be good for 600hp plus.
Im scared that if i go to big with the cams it will have no power in middle and low and it will only be a topend screamer!!
Any suggestions??
It will be used for normal road mainly, and ocational drifting and drags!!
Any suggestions??
