Posts: 3882 Joined: Wed Jan 09, 2008 10:08 am
Post
by Charlvdw » Thu Feb 05, 2009 8:58 am
Hi *
My hand brake light comes on from time to time. Fluid levels are fine i havent checked the switch yet. Any idea's on what this could be?
Sokar
1.0 Bar Boost
Posts: 1055 Joined: Wed Nov 08, 2006 9:30 am
Post
by Sokar » Thu Feb 05, 2009 12:20 pm
Charlvdw wrote: Hi *
Uuuuuum, my money is on the switch....
They tend to come loose and short on the body.
Captain Slow to the rescue!
Post
by Charlvdw » Thu Feb 05, 2009 3:28 pm
Thanx will check it tonight.
Posts: 2078 Joined: Fri Sep 21, 2007 10:18 am
Post
by Drillergy » Wed Feb 18, 2009 11:35 am
Wheres the switch located??????
Mine comes on in the morning after a while it goes off.
Post
by Charlvdw » Wed Feb 18, 2009 11:59 am
Same here. If you remove the boot over the hb lever it sits on the right of the lever. I did check mine and it seems fine. Stil on in the mornings tho.
Post
by Drillergy » Thu Feb 19, 2009 8:26 am
So I inspected the switch, cleaned it but still same problem in the morning.
So Im gonna try flushing the brake fluid out and check again.
Post
by Charlvdw » Thu Feb 19, 2009 8:45 am
@Drillergy
What you fluid level like?
Post
by Drillergy » Thu Feb 19, 2009 9:03 am
Its not full its inbetween full and empty. The last time I checked.
Post
by Charlvdw » Mon Mar 09, 2009 8:43 am
Filled the fluid = sorted no more light.
Post
by Drillergy » Mon Mar 09, 2009 9:06 am
Charlvdw wrote: Filled the fluid = sorted no more light.
Same with me but I need to upgrade my brakes soon.
Post
by Charlvdw » Mon Mar 09, 2009 9:56 am
Thicker sole shoes the deeper the paddle goes the quicker you stop.
