ReeceZ
Posts: 1876 Joined: Sun Jan 20, 2008 1:36 am
Post
by ReeceZ » Fri Jan 02, 2009 11:11 pm
Howzit gents, the green light indicating that the airconditioner is on isn't coming on anymore, nor is the aircon working even when the button is pressed. Is that the car's notification to get the aircon re-gassed or is there something else wrong? oh its an S13 btw
thanks
poizen
Posts: 2994 Joined: Sat Apr 12, 2008 2:05 pm
Real Name: Mical Mackay
Post
by poizen » Sat Jan 03, 2009 2:49 pm
check your aircon fuse and relay
widowmaker
Posts: 3051 Joined: Wed Aug 02, 2006 9:50 am
Real Name: Walter
Post
by widowmaker » Sun Jan 04, 2009 11:29 am
light does stop working when gas is out...
Posts: 5378 Joined: Sat Jun 30, 2007 10:38 am
Post
by rat » Mon Jan 05, 2009 3:10 pm
are you still using the std management? if you have changed it you going to need to rewire the a/c
ReeceZ
Post
by ReeceZ » Tue Jan 06, 2009 9:17 am
Really?
I'm sure Gary will sort that out when i put the tator in.
Guy
Posts: 327 Joined: Tue May 13, 2008 8:28 am
Post
by Guy » Thu Jan 08, 2009 3:03 pm
Mine kept on blowing the fuse when it was running, any idea what causes this?
ReeceZ
Post
by ReeceZ » Thu Jan 08, 2009 6:46 pm
Guy wrote: Mine kept on blowing the fuse when it was running, any idea what causes this?
Do u also have stand alone engine management?
Guy
Post
by Guy » Fri Jan 09, 2009 8:16 am
No, totally standard.
