Beast
Newbie
Posts: 6 Joined: Wed Dec 17, 2008 7:46 pm
Post
by Beast » Wed Dec 17, 2008 9:30 pm
Help plz..wen i start my car it runs fine,as soon as idle sets to 1000rpm n engine is warm.if i rev it hard the revs drop al the way dwn n abt to cut off then stabalises at 1000rpm..also wn drivin if i drop the cluth n hit brakes the revs js drop n the car cuts..any ideas as what mite b the prblm???
HancoB
Posts: 2240 Joined: Thu Feb 21, 2008 10:49 am
Post
by HancoB » Wed Dec 17, 2008 9:48 pm
Do you have a BOV?
Does it close after dumping?
Do you have any air leaks?
Check all the vacuum pipes and make sure they are connected.
Some more info on your mods and engine then everyone can help you.
HancoB
Post
by HancoB » Wed Dec 17, 2008 9:56 pm
Oh yeah and BTW...
Welcome to the forum beast...hope you get your beast running right soon!
ChemCool
Posts: 2195 Joined: Tue Aug 01, 2006 11:59 am
Post
by ChemCool » Wed Dec 17, 2008 9:56 pm
TPS, this was covered before, also see service manual, to set tps, for idle switch setting.
Chem
Posts: 3882 Joined: Wed Jan 09, 2008 10:08 am
Post
by Charlvdw » Thu Dec 18, 2008 7:32 am
I think Chems got it there ,but also make sure your spark plug are lekker and the gaps are right(exectly right).
widowmaker
Posts: 3051 Joined: Wed Aug 02, 2006 9:50 am
Real Name: Walter
Post
by widowmaker » Thu Dec 18, 2008 9:28 am
coil packs... no fire and your pots get full of petrol
jon
0.7 Bar Boost
Posts: 758 Joined: Wed Nov 29, 2006 12:05 pm
Post
by jon » Thu Dec 18, 2008 1:12 pm
When was your car last serviced? I had a similar problem until my petrol filter was replaced.
It's probably plugs or coil packs though.
Diesel power, hmm, yes, I think I'll have some of that.
Beast
Newbie
Post
by Beast » Thu Dec 18, 2008 2:31 pm
Hey guys.tnx fr the warm welcme..its runing on a high presure fuel pump,fuel regulator,biger injector,garett trbo,blitz boost controler,frnt mt intercooler,air intake and aftrmakt exhaust..no bov..!i cnt seem to find the service manual for idle seting....tnx again
Posts: 5975 Joined: Thu Oct 12, 2006 12:56 pm
Post
by Gary57 » Thu Dec 18, 2008 2:40 pm
How do you control the fueling if its the stock ECU??
Beast
Newbie
Post
by Beast » Thu Dec 18, 2008 6:21 pm
It does have an aftermakt comp box..
Toby
Club Founder
Posts: 1874 Joined: Tue Aug 01, 2006 10:44 am
Real Name: Toby Kurien
Post
by Toby » Thu Dec 18, 2008 7:43 pm
Sounds to me like it's overfuelling...
Post
by Charlvdw » Fri Dec 19, 2008 7:22 am
Check da plugs.
Post
by Gary57 » Fri Dec 19, 2008 8:03 am
Take it to a tuner to sort out.
Beast
Newbie
Post
by Beast » Fri Dec 19, 2008 9:39 pm
I wud if i cud..im frm zambia and no tuners ere..i fited new plugs n i increasd the idle a litle..not cutin of on me..stl trble shooting...
