2JAYZEE SX ( dyno sheet up)
- n1smo200sx
- 0.5 Bar Boost
finally heres the dyno sheet
I should receive the car on the 20 december 2008
Ill post some pics so you can see the finished project
Well engine wise atleast
There is still alot of work to do, But ill do it in stages
Brake upgrade will be done as soon as i get it
s14 hubs
Atleast i be able to drive it.... I really cant wait for next week
s14 hubs
- n1smo200sx
- 0.5 Bar Boost
its a T72 comp and T66 exhaust
Bearing in mind that at the coast if will start making the power from about 3000rpm, which is cool with me as i dont want scare people with my screamer pipe to early
The dyno guys said they could not keep the car down , it was spinning on the dyno
The clucth has failed already, Had to put in a stronger one
But hopefully next year i can afford a clutch master flywheel and double clucth..... Very expensive though
Andre reckons at 4000rpm she start wheel spinning like hell
so i have no idea how im gona keep the power down, So im starting with
18" semi slicks to run, later im looking a some Tein Super street Coilovers,
What im really happy about is that on my high boost at 1.1 bar it made 379kw on the wheels ........Thats My
500 hp target achived[/b]
- n1smo200sx
- 0.5 Bar Boost
- Riaan 2JZGTE
