Turbo intake pipe.
Turbo intake pipe.
I got a 76mm pipe bent for my turbo intake and when they bent/rolled it, it went oval. It now measures 76mm and 65mm across. Do you think this will make a big difference in the flow and performance, I mean big enough for me to get another one made??
Ok well a symptom of a restrictive intake is a drop in boost pressure at high RPM before the turbo's physical operating range ends.
So say the turbo coupled with your engine is designed to run to 5500rpm with full boost starting at 2500rpm. A restrictive intake would see a drop in boost at 5000rpm rather at 5500rpm. Hope this helps.
2002 Astra Coupe Turbo - 131.8kw and 291nm ATW
Looking for S13 200SX
It had a huge difference on my car.
That rubber pipe is crap .
A.K.A - Wonderboy
1993 Nissan 200 SX
1989 Toyota Corrola
63kw - 117nm 1.3- N/A
1993 Nissan 200 SX
1989 Toyota Corrola
The Calibrator
- 0.4 Bar Boost
