Its possible to make the CA18 make 500wkw, it just depends how much money you want to spend,,
One of the biggest things for track days is oil volume, oil temprature and cooling, coupled with a very safe map, any knock at continued higher RPM driving will kill it fast. get your oiling and cooling done properly and you will reduce your chance of engine damage at the track 10 fold no matter what power you run.
Calling all ex CA18 & SR20 engine build owners
Ok seriously I dont get the point of all this fighting!
If you want something to last long dont push it to the edge, dont mod it, be happy with stock. There is a reason why they built it that way!
and go with what you like, if you like CA then go CA, if you like SR then go SR, if you want RB then go RB.
Make sure you have the money to do what you want. If you dont have the money dont bitch about it and then dont try to do it!
and all these mad figures that was given...uhm damn guys!
G, go with what your heart tells you! You will have to drive the car not the other people. If you dont like what you drive then why do you.
I like my CA18, its my daily drive, never gave me a bit crap and its old.
To me its like a Alfa, even tho they are so crap it just gives you this warm fuzzy feeling when you drive it.
ITS ALL ABOUT WHAT YOU WANT AND WHAT YOU LIKE! screw the other people!
Interesting read, as for G's original Q:
My rebuild cost about R10k:
- Engineering = R3360 -> Includes lighter flywheel, balanced, head line bored and rebuilt with new valve stem seals, etc.
- ACL bearings
- Rings
- Pumps
- Timing belt
- DE cam (got this for free though)
- Gasket set
- Clutch rebuild (upgraded pressure plate + replaced copper)
- Pilot bush
- Engine temp sensor
- Fan temp sensor
- Accessory belt for A/C (re-installed my A/C - just hope it works)
Anyway - originally though it would cost about R7k and I could maybe add Arias pistons. The costs where way higher than originally planned (this was sort of expected though after realising how the motor was stuffed up by Snail) and I couldn't afford forged stuff.
I feel that the motor was built right with no short-cuts but built within a budget - I don't think the motor will be hugely powerful, though. (Don't know as I'm still running it in only done 550km's since rebuild)
I retain what I had before:
TD04HL-16T
Exhust
Filter
Adjustable FPR
In my opinion: Will I do it again - Yes, I had no choice as piston 2 was turning in the bore
. As for the costs - could have saved a few bucks with cheaper bearings, but that misses the point of doing the rebuild. Lesson learned - engineering work is expensive!!!!
My final 2c - The most important bit to get decent power (and my next mod once I can afford it): TUNING. whether it be nistune/gotech/whatever.
PS: Thanx again for the help PFB - I really appreciate it. I was seriously considering torching the car but having somebody help out saved my SX's life....
- ACL bearings
- Rings
- Pumps
- Timing belt
- Gasket set
- Pilot bush
- Fan temp sensor
TD04HL-16T
Exhust
Filter
Adjustable FPR
