tein vs apex
tein vs apex
howsit guys
im been looking at getting a set of lowering springs for my s13 and im thinking apex R1600 tein R2200 plus minus.
Any thoughts, cars going to be driven every day the odd drift. im looking for handling and looks and down the line when i change shocks i would like to buy a set of shorten shocks which i have no idea where im going to get it from.
- mario_200sx
- mario_200sx
Lowering kit will give you more camber already, and the rest you can slightly ajust with the stock system. You dont want anymore camber than that..... Unless you gonna make it a race car!
My cars camber is 100% for the way I drive and I only put on a lowering kit. Its more difficult to get it in a slide with the camber I got now but if it does start sliding its easier too handle. (Please dont ask me what the camber is cause I got no idea!
Rolling Thunder..........
- mario_200sx
The stock setup can adjust, but to be honest, when you use a lowering kit(just springs) the stock setup won't be able to get the car back to stock camber. The stock parts can adjust less than half a degree.
When I did my coil overs the rear camber was -3 degrees. I dont think the stock arms would adjust that much to get it back to normal.
NIZAN-R
- Real Name: Renier
J
I got origanal tein stec springs from import parts for R2300 and it works like a dream .cheap stuf is hard as hel so beware of that you can also see some picks of the springs in my project
She is the CA that IS
(O=O)/RS13\(O=O)
"EVERYDAY I'M FLUTTERING!"
Well its about R11k for a complete set at Nisscamettienne wrote:sounds like tein it is, thanks for the info guys i would be lost with out the forum.
About the shocks though u guys say i dont need shorten shocks...? but when i do need to replace shocks heard nissan wants 2 arms and twenty legs for a set of shocks... is this true.
