1/4 record
Going fast in a straight line
Bigtone
Newbie
1/4 record
Post by Bigtone »
hi everyone..
thought Id let you all know...
my CA has just done a 10.8 @ 136mph
we believe its a new European record...
we should be quicker next year when we fit uprated driveshafts after
snapping 4 last time out (too much grip off the line for standard ones)
cheers Tony..
Man that is fast......fly over here and take me for a spin :D
Hey man you cant just post something like that without pictures or specs on the motor. What power does it make, what mods, etc...
Come on share please :lol:
Gary57 wrote:Hey man you cant just post something like that without pictures or specs on the motor. What power does it make, what mods, etc...
haha! how gary's listening!! hehe
Bigtone
Newbie
Post by Bigtone »
a few pics...
we are running about 700+ bhp (at the mo)
we made a bracket and fitted an electric power steering pump..
the dry cell battery..
boost controller..
a thing to hold all the new fuse's..
and a stack of pipe work..
if you want to see the whole project click my sig...
cheers...
Bigtone
Newbie
Post by Bigtone »
engine spec..
1809 4-cylinder turbo 16v twin cam, (CA 18 DET)
Motec engine management system,
New loom,
Tomei vernier cam pulleys,
Metal head gasket 1.2mm,
Trust steel H section con rods,
Forged pistons,
Garrett GT35R/40 Turbo,
ND custom exhaust manifold,
External wastegate,
Large flow custom plenum,
80mm throttle body,
Port / gas-flow cylinder head,
Match / port inlet & exhaust manifolds,
Re-shape / equalise combustion chambers,
Re-profile valves,
One off steel crankshaft,
Tomei / HKS re-profile cams,
Solid lifters,
SARD adjustable fuel pressure regulator kit,
Dash 8 Fuel line (delivery),
Dash 6 Fuel line (return),
SARD 1200cc Injectors,
Custom made fuel rail,
Custom made fuel tank, baffled and foam filled,
Gp B external fuel pump,
Custom large radiator,
Stant high pressure radiator cap,
Electric fan,
Custom made header tank,
Custom made vapour tank,
Custom large intercooler kit with 3"pipes,
Custom made oil catch tank,
Large oil cooler,
Oil breather system,
Blitz SUS air filter,
5bar map sensor.
HKS m40i plugs,
Evo 7 coilpacks.
Nismo engine mounts.
widowmaker
Real Name: Walter
Post by widowmaker »
CA18??? 10.8? HONOLULU!
are the quarter miles shorter over there?
nice!
Pinkfluffybunnys
Real Name: Ashley
Post by Pinkfluffybunnys »
NIce Bigtone...
Fly the CA18DET flag high
1\4 Mile:
Because Race Car
Your link says error...
Did you build the motor??
Bigtone
Newbie
Post by Bigtone »
Gary57 wrote:Your link says error...
strange the link works for me????
initially the engine was built by Norris Designs but we have had it
stripped twice and rebuilt it twice ourselves..
but Norris is the only one that map's her....
Lindt
Post by Lindt »
I love the headlights, should weight a lot less than the stock ones with the motors and lever arms.
