Good Times??
- Slide 'em Wide
- 0.6 Bar Boost
Good Times??
Hey, I ran @ Kilarney last night in the wet and it was dark. I posted a time of 14.05 on the quarter.
I F%&ked the start and started braking B4 the line.....(i dont really drag) My 5th time down the strip, 1st time in my sx.
Is this respectable??
What is a good time for a stock s14 with a leetle more boost.(.8 bar)??
What Id rather be dooing!
- mario_200sx
- THEO 3K - ZN
That is a very good run for a stockish S13, almost can't believe that it only has a bit more boost, makes me wonder what I would have done on the 1/4 mile...always thaught I would get around there but maybe it was possible to get mid 13's.....
With your stockish one you should get flat 14's or late 13's if the launch and urly braking is sorted.....which is extremely good for a "claimed" stockish S13....
- mario_200sx
- Slide 'em Wide
- 0.6 Bar Boost
If you have slicks or semi's on yes, maybe even 13.3 or so....normal tyres you should get 13.7 ish if you have a clean good run with perfect gearing and no tyre spinSlide 'em Wide wrote:Hey guys been MIA!
Yeah, very bad off the line!!
Once i hit 2nd it was all goo until i hit the breaks!
Gary with th 200wkw mark 13.5s should be easy!
So I will be in the 14s thenIf you have slicks or semi's on yes, maybe even 13.3 or so....normal tyres you should get 13.7 ish if you have a clean good run with perfect gearing and no tyre spin
