injector upgrade
injector upgrade
Hey guys
I was wondering what kind of gains could be expected from upgrading the std injectors to
650cc. has anyone done this?
ex. kadett 1.3 ls
ex. kadett 1.4 s
ex. kadett 1.8 glx (slightly modded)
ex. kadett big boss turbo
ex. Blue Nissan 200sx 93
ex. White Nissan 200sx 92
ex. Red Z32 Nissan 300zx TT 91
Nissan 200GXI
Corsa Lite 1.4
ex. kadett 1.4 s
Nissan 200GXI
Corsa Lite 1.4
Yeah!!! 3kms/l @ R147.43 per liter means u r f@kd.
No seriously - big injectors = big power (if you have the right motor of course).
Another thing to bear in mind is that if the injectors are too big you won't get proper fuel atomisation as injection occurs - this will lead to erratic ignition, heavy fuel consumption and no power.
well currently i have a
- 63mm exhaust
- diktator
- and i recently rebuilt the std T25 turbo (don't know the terminology but something was done to it so i can safely boost at least 1.2 bar and it is still under guarentee from turbo exchange )
i made 150kw on ferrolli's dyno on 0.8 bar boost.
but cylinder 3 was running a bit lean after checking the spark plugs we turned the boost down to 0.6 again for reliability.
So i am thinking if i get 650cc injectors i should safely be able to up the boost more and make more power. I have asked around and found quite a few std 18det (and by std i mean stock block ) running on at least 1 bar boost.
Are any of you guys doing it?
Is it reliable?
What kinda power are you guys making?
- 63mm exhaust
- diktator
Is it reliable?
ex. kadett 1.3 ls
ex. kadett 1.4 s
Nissan 200GXI
Corsa Lite 1.4
ex. kadett 1.4 s
Nissan 200GXI
Corsa Lite 1.4
650cc injectors well my mech can get them for R650 but neva asked what brand .Gary57 wrote:Nothing unless you are maxing your injectors out now.
How much can you get them for??
Otherwise I can get RC injector R3600 for a set of 4.
Can you get it for a better price?
ex. kadett 1.3 ls
ex. kadett 1.4 s
Nissan 200GXI
Corsa Lite 1.4
ex. kadett 1.4 s
Nissan 200GXI
Corsa Lite 1.4
650cc's are probably too big for a stock engine, t25 and stock management...
i'm not sure though so you should probably expect a better informed statement from the likes of gary or pinkfluff.
just noticed you running dictator - so you could manage the extra fuel capacity. so getting them shouldnt really be a problem, but with that T25 dont expect big gains!
a t25 is out of its efficiency range at around 0.9 bar - so boost much more than that and you will only be blowing hot air into the motor, and overspinning the turbo shaft!!!
0.9 bar mmmm.....
Is anyone running a sx with a smiliar setup to mine exhaust etc
boosting 1 bar reliably on a stock block? Wat kind of power gains can be expected guys?
At the end of the day i just wanna know if its worth it upgrading the injectors.
Cos its prolly gonna set me back about 4-5k just to do this with injectors , fuel rail and tuning.
Also keep in mind that I only wanna do generic mods at this stage so that when i do my motor swap its one less thing i have to buy.
ex. kadett 1.3 ls
ex. kadett 1.4 s
Nissan 200GXI
Corsa Lite 1.4
ex. kadett 1.4 s
Nissan 200GXI
Corsa Lite 1.4
In my opinion just go for a T28 turbo and larger intercooler for now. cause you already have the management system and exhuast. thats what I'm gonna do. Will do the injectors eventually but only when I max them out...mono wrote:0.9 bar mmmm.....
- Toby
- Club Founder
- Real Name: Toby Kurien
There's something weird about the stock injectors. It's rated at 375cc or whatever. Last weekend I decided to try to get a replacement for my leaky ones. Had my injector tested on a jig with a known 388cc brand-new injector. At the same fuel pressure and duty cycle, the stock injector flowed almost DOUBLE the amount that the 388cc injector flowed! The mac claims that the stock ones are more like 550cc or something.
This would explain why, when I got injectors custom-made to 375cc, my car wouldn't even idle with them.
I'm really confused about the injector capacity. Is it possible that there are different standards for measuring injector flow rate? For example, the japs maybe use a different duty cycle or pulse duration or fuel pressure, etc. when testing flow?
its possible... i mean they measure power in PS. its almost the same as HP, but a lot different to Kw.
anyway i have the opposite story. i got an injector leak on my first set of injectors with the ca18. i pulled those out and noticed that they had different part numbers to what i thought was stock.
i had them sonically cleaned and flow tested. they measured in at about 200cc, not the stock 370cc. but my car was running perfectly fine on those injectors???? i changed to the stock ones immediately after that, and there was no change in the engine performance!!!???
Im doing a RB swap later in the year and then i will probably invest in a new turbo.
For now im just trying to buy strengthen everything round the motor to reduce costs when i do the actual swap.
ex. kadett 1.3 ls
ex. kadett 1.4 s
Nissan 200GXI
Corsa Lite 1.4
ex. kadett 1.4 s
Nissan 200GXI
Corsa Lite 1.4
