Air Temp Sensor wanted
Wanted or for sale
Locked
Vlade
* - Club Pimp - *
Real Name: Barend
Post by Vlade »
Hi all I require a Air Temp Sensor, the screw in type
I think Gary might also find this usefull...
Hairdresser MX5
widowmaker
Real Name: Walter
Post by widowmaker »
that looks like the kinda thing that you can get from a sentra - no?
ChemCool
Post by ChemCool »
And to what type of temp meter you connect it? Digital or these anlogue goodies from autostyle and then if analogue, what will the response time be on various temperatures ? Vlade what an where temp you need to evaluate. Asking this, because I am trying to resolve somethng similar in front of TB
COOLER, FASTER, LIGHTER
Chemcool should be able to help with that.
Vlade
* - Club Pimp - *
Real Name: Barend
Post by Vlade »
That is a Delco type sensor that can be used by my Wolf EMS, the one I have in now, came from an Opel Astra, but I got the same problem as you Freddy it started to leak, got it wired and siliconed but don't think it would last long, so Ja trying to source a screw in type of connector.
Hairdresser MX5
I got a DENSO air temp sensor off a Toyota. Its a screw in type as well, M16x1.5. I just drilled and tapped it into my plenum, fits nicely and look std :D . The Denso's element is in a ceramic housing which helps prevent heat soak and incorrect reading.
What are you using it for??
ChemCool
Post by ChemCool »
Gary, plse tell exactly where on the plenum you drilled etc. Side,top, back.
Is there place just after the throttle fly?
Vlade
* - Club Pimp - *
Real Name: Barend
Post by Vlade »
Mine is for my Wolf... Freddy wants to monitor his water mist system...
Gary can you get some more details what Toyota?
Hairdresser MX5
Just behind the TB on the motor side, there is a flat surface which is real cool, looks like it was made for the sensor :lol: .
Mine is for the wolf aswell but also to monitor my water injection, to see what difference it makes.
All the Toyota's use the same sensor as far as I know.
DENSO 89424 60010 1T 20.
ChemCool
Post by ChemCool »
Gary cool man. I already mesured and results as low as 29 deg Celsius before TB. Highway driving sort of. Ambient was about 27 to 29. Intake air before filter sometimes as high as 42 deg Celsius.
Locked
