![200SX_confused1 [smilie=200sx_confused1.gif]](./images/smilies/200SX_confused1.gif)
CA18DET ECU Information - not anymore
- Pinkfluffybunnys
- Real Name: Ashley
Last edited by Pinkfluffybunnys on Thu Jun 19, 2008 10:21 pm, edited 1 time in total.
1\4 Mile:
Because Race Car
1\4 Mile:
Because Race Car
- 200SXSilviaSavage
- Pinkfluffybunnys
- Real Name: Ashley
Last edited by Pinkfluffybunnys on Thu Jun 19, 2008 10:21 pm, edited 2 times in total.
1\4 Mile:
Because Race Car
1\4 Mile:
Because Race Car
Ja I also wanna know!Daniel wrote:now what does this mean exactly?* Nissan was extremely conservative with regards to timing on the CA18DET the same can been see on the SR20.but not to the same extent.
- Pinkfluffybunnys
- Real Name: Ashley
1\4 Mile:
Because Race Car
1\4 Mile:
Because Race Car
- rat
- Car: R32
- Real Name: Rat
do the sa one have that?* First off the Speed limiter is set at 224KM on all Euro model maps,
do the sa one have that too?The Japanese 8 port model ECU’s (Mec-0012) have very different timing and fuel curves below 4400Rpm to make use of the 8 port butterfly system running close to 13.1 AFR before the switch
- Pinkfluffybunnys
- Real Name: Ashley
Last edited by Pinkfluffybunnys on Thu Jun 19, 2008 10:21 pm, edited 3 times in total.
1\4 Mile:
Because Race Car
1\4 Mile:
Because Race Car
High load is what exactly, 0.6Bar or 0.8Bar??
Those values are true timing am I correct?? meaning 51degrees is 51degrees BTC??
That is 1 hell of a high timing curve, 40degrees plus is high, I only run 30s. Pink where did you get this info from, just want to know how reliable it is. I am VERY keen to try upping my timing in the low load ranges.
- Pinkfluffybunnys
- Real Name: Ashley
1\4 Mile:
Because Race Car
1\4 Mile:
Because Race Car
