300zx front disc/rotors
RBSX
1.0 Bar Boost
Post by RBSX »
Hi guys I can get Brand new 300zx rotors 280/30mm
if i get them redrilled to 4x114 pcd, will they be a fine
I dont have the five lug hubs
300sx
0.8 Bar Boost
Post by 300sx »
yup, redrilling them works perfect..
use your old rotor , bolt it through 1 of the holes to the new rotor, and voila
you know exactly where to drill the other three.. 8)
Doctor G
0.7 Bar Boost
Post by Doctor G »
300sx wrote:yup, redrilling them works perfect..
I would probably take it to a mag repair shop to do. In case drilling it at the wrong speed heats/weakens the metal or in case the pcd isn't quite 110% accurate. But I guess DIY could work.
RBSX where can you get these rotors? I need some too please. Can you get rears also?
300sx
0.8 Bar Boost
Post by 300sx »
yeah, the way i descibed is the poor mans way.. :lol:
engineering works would prolly be a better idea..
btw, i would also like some if you could get them at a reasonable price?
DIY should work perfectly, unless you're totally useless with a drill and a ratchet, and lining holes up!!!
and as for docs question - where can you get and how much yo??? i also have a set of 300zx calipers and i'm short a set of 280mm/30mm rotors!!!
300sx
0.8 Bar Boost
Post by 300sx »
seems a lot of guys want them discs... cheep cheep :lol:
hard to source/import (heavy)
RBSX
1.0 Bar Boost
Post by RBSX »
nissan umhlanga can get stock
so should i buy them already
How much??
yeah - what prices???
