oil - your choice
is the pope a catholic?
is the ca18det unreliable?
does a bear shit in the woods?
veecee wrote:is the pope a catholic? YES
is the ca18det unreliable? MAYBE
does a bear shit in the woods? HOPEFULLY[
COOL!
HancoB
Post by HancoB »
Yes Riekert, I got mine there.
HancoB wrote:Yes Riekert, I got mine there.
ROFLOL - you got your synthetic oil there???:? :? :?
hehehehehe!!! :lol: :lol: :lol:
HancoB
Post by HancoB »
I was reading a article on oil the other day in the mens health, and they said gays tend use synthetic oil. They say that first hand experience proved that synthetic oil lubricates a lot better and under hard working conditions lasts a lot longer and does not cause damage to the exposed areas!
Maybe Gary was right...he mos uses that. :lol: :lol: :lol:
HancoB wrote:I was reading a article on oil the other day in the mens health, and they said gays tend use synthetic oil. They say that first hand experience proved that synthetic oil lubricates a lot better and under hard working conditions lasts a lot longer and does not cause damage to the exposed areas!
OMW it starts again
HancoB
Post by HancoB »
It was meant as a joke to end it all! Hence the :lol: :lol: :lol:
only gay metrosexual guys read mens health!!! :lol: :lol: :lol:
and i thought you were a dutchman, hancoB???
I am the biggest Homophobe out, you lucky you posted this before I replied.
To end it all, Hanco you have your oppinions and I have (mine are right of course :lol: ). Use whatever oil you want, just dont preach synthetic oil is the same as mineral.
Reikert: Use Castrol SLR (used to be Softec TXT). It is about R60/l and you can buy it in 1 liter bottles which is cool, great oil.
Pinkfluffybunnys
Real Name: Ashley
Post by Pinkfluffybunnys »
The friction-fighting properties of synthetic lubricants have been well established by now. Second only to making sure you change your oil at regular intervals is the need for a high-quality synthetic oil. Even if we disregard the performance benefits offered by the reduced friction, the improved lubrication and protection from thermal breakdown are reason enough to step up to the cost of synthetic lubricants. Not filling the crankcase with synthetics can be likened to running your turbo engine on low-octane fuel. Under most conditions, your boosted engine will tolerate the cheap stuff, but when you really need it most, the lesser octane can subject your turbo engine to deadly detonation. While the oiling situation likely won't be as dramatic, it is possible to spin a bearing or two under the heat of battle using conventional oil. Sure, synthetic oil is slightly more expensive, but a portion of the added cost can be recouped by lengthening oil change intervals since synthetics are less susceptible to contamination. But even if you do choose to schedule your changes every 3,000 miles, doesn't your performance engine deserve the good stuff?
As with the normally aspirated engine, gains increased with engine speed on the turbo combination as well. The Lucas synthetic oil improved the power output of the turbo engine by 10-11 hp.
Thanks Turbo Magazine
1\4 Mile:
Because Race Car
widowmaker
Real Name: Walter
Post by widowmaker »
sounds like marketing - the question was "can you prove it"
:D
come on dont give up hanco! i thought you were winning!
HancoB
Post by HancoB »
Nah Widow best not to stand your ground on the forum. People might lose what their mommies gave them!
So I just listen to what they say and take what I want to hear.
Fighting on the net??? thats for tossers!
Slide 'em Wide
0.6 Bar Boost
Post by Slide 'em Wide »
Dont tossers use lubricant?
now i wonder......
Synthetic
OR
Not?!?!
What Id rather be dooing!
Slide 'em Wide wrote:Dont tossers use lubricant?
now i wonder......
Synthetic
OR
Not?!?!
I'm going synthetic.... Castrol txt R45/l... so ya.... And I'm no tosser
Slide 'em Wide
0.6 Bar Boost
sssshhhhhh!!!
Rikert, I was trying to start another argument!
you no fun!! :?
