fan switch.
- AR 200SX
- 0.2 Bar Boost
- Car: S14
- Real Name: Armand
fan switch.
where would be the ideal place for a fan switch? top or bottom hose?
Ero_sennin
Ero_sennin
i had a bmw 3 series switch on my ca18 which gave me two temp settings, 80 something degrees and 90 something degrees.
i had 2 electrical fans setup, the lower switch would turn on the first fan, and the higher temp switch would turn on the second fan!
More advice, if you run 2 fans, use a 30 amp relay, most fans use about 7.5 amps each, so u connect the switch, from there to the relay and the relay splits to the fans.....switching them on and off as the temp switxh goes on and off......and guess what......it's done buy the same switch
Ha ha ....can't help mocking VC.....
- AR 200SX
- 0.2 Bar Boost
- Car: S14
- Real Name: Armand
fan switch
i have a 82' fan switch and the thermostat opens @ 76'. and i am using a relay cause it's 2 12 inch fans. fitted it in the bottom hose and it seems to work leka.
dont be a tjop draco...Draco wrote:Wow thats cool VC......
i meant the same switch unit turns on the first fan at 80 something, and then turns on the second fan at 90 something.
that means i only use one fan while the temps aren't that high, but if it gets too high then both the fans run at the same time!
Just don't eat me VC....please!!!!! I know I'm a tjop but I'm not lekke
Was mocking you a bit grumpy, cos you did not make it clear....us tjops don't read around the corner you know.....
I got all tjopped eyed when you said "the lower switch would turn on the first fan, and the higher temp switch would turn on the second fan!"
My bad.....I'm a special tjop....
LOL - you clown!!!Draco wrote:Just don't eat me VC....please!!!!! I know I'm a tjop but I'm not lekke![]()
sorry if i musunderstood you!
