Since I bought my 200sx in a non running condition, there were some things that needed tending to.
Firstly : the starter would turn for quite a while, backfire a good couple of times trough the exhaust, and then fire up. Ran for about 1 second ,and then died.
To me, this spelled one symptom…. Ignition Timing!
Now I’m not very knowledgeable with Pistons engines at all. Although I understand it, and have modified quite a few of them, the thought of 16 valves, 4 pistons, little sticks being turned with a belt just generally scares the crap out of me.
So the help of Turbonutters was called in.
We removed the CAS, and there was a very nasty surprise for us there…
The drive in the exhaust cam, was broken off. It didn’t seem like it was the result off abuse, but rather it got worn out slowly over the years. What to do, what to do?
Decided a new pin would do the job! So we took a piece of high tensile strength shaft, and turned it on the lathe.(refer to the pics please)
We knocked the new pin in, and reinstalled the CAS. Setting the timing roughly.
Turn the key…chi-chi…VROOM!It was purring like a small Ginger colored kitten!Yeehaaa! Ride em cowboy!
Ran smoothly for a few minutes, and then it died. Oh crap. What now????
CAS came out again. The brand new machined pin, had broken off. Halo??Was the machinist drunk by any chance?(Actually, slightly intoxicated, as were the rest of us,hahaha)
The Exhaust cam pulley had some scuff marks on it, where the new pin was grinding away..
What do we do now?
I took off all of the front engine covers, radiator cowling, cam belt and various other weird things that 4 cylinders use! I was making sure that the broken off pin wont cause poo-pee. We found it at them bottom of the crank pulley. Thank goodness!
What to do now?
Installed everything back where it was supposed to go. Took off the exhaust cam pulley, and made a slot in it. The little slot will provide a space for the pin to fit into, and not break off again!
Arrrghhh! We be clever after beer!
Fitted everything in, and it was once again running like a ginger colored kitten!The test drive followed
Part 2 Will follow shortly!
