Old setup:
It all started with the kit: (Apologies for the terrible pics taken on my phone, as that was all I had at the time)
600x300x76mm IC and Aluminium piping
I eventually found out that cutting would be inevitable...
Finally got the pipes through and could mount the intercooler...
The IC mounted and all pipes ready for connection...
The cowling had to be cut to make space for the dump valve. This made the cowling weak. We went for a run, and came back to see that the viscous fan had taken a chunk out of the cowling at the top...
We took the cowling out and with the huge viscous fan sticking out, it wasn't at all safe! So I decided to take the fan out and replace it with two 12" electric fans...
The intake piping from the filter to the turbo was redone too...
A smaller battery just fitted in place so I didn't need to relocate it. The battery and the water containers were painted...
The front of my car with the cooler...
And finally, after 5 days of work, the complete new setup! Lag has surprisingly not increased and power distribution is much smoother
