noisy lifters
- ChemCool
I called the part shop again. Vivian is the guy who assisted me. He has alos helped me out before.
I confirmed the price with him. R39-00 bucks plus vat to be added.
He still cant get stock. So, let see what happens.
Speedbreeder, I forgot to ask the part number. If he call hopefully this afternoon, I will ask him on that.
Chem
BTW: feel free to call: Vivian at Dynamic engine parts. 0123267476 This is the dude who's parts shop is close to Ero Sennin's place and who also assisted Ero with pads if not mistaken.
Chem
Mmmmm... well for that price count me in... Mine also almost on their way out...ChemCool wrote: I confirmed the price with him. R39-00 bucks plus vat to be added.
- ChemCool
Question?
Will noisy hydraulic lifters (worn lifters) be a culprit for a valve not closing properly, and if that is possible, will there then oil leaking into the combustion chamber? Resulting in oil being burned and hence blue smoke from the exhaust during warm up time of engine and then during revving of the engine to plus minus 2.5 /3K R.P.M. Once the engine is warmed up properly, or after a short drive, the blue smoke disappears. The moment when you start up again after long parking, the blue smoke will appears again. OR is it purely to worned valve stem seals(in my case brand new since rebuild) passing oil to the combustion chamber. Or the valve stem seals will prevent(or suppose to prevent oil reaching the open valve due to a worned lifter?
I must be honest, if this question does not make sense it is purely because I don't have the knowledge
Chem
Chem
Doesn't sound to me like valve stem seals. Those will smoke all the time at high rpm and high rpm gearshifts.ChemCool wrote:Question?
I must be honest, if this question does not make sense it is purely because I don't have the knowledge![]()
Chem
Sounds more to me like worn rings/pistons or incorrect clearances. Therefore the smoke when it's cold. Once the rings/pistons reach operating temperature they expand, causing a better seal and no more smoke.
I could be wrong but that's my guess chem.
